```cpp
#define BLYNK_DEBUG
#include <DHTesp.h>
//#include <DHT.h>
char auth[] = "xxxxxxxxxxxxxxx";
char ssid[] = "xxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxx";
#define TempHumPin D4
DHTesp dht;
//DHT dht(TempHumPin, DHTTYPE);
float AnlogVal;
boolean debug=false;
int HomePos = 93,dlay= 10000, Speed=10; // homepos was 92
int startHr=5,stopHr=0,startMin=0, stopMin=0,SpdModifier=0, EndDelay=0,i;
String StartTime="5:00",EndTime="",LightCycle="24-0";
pinMode(TempHumPin, INPUT );
// dht.setup(12, DHTesp::DHT11); // Connect DHT sensor to GPIO 12 - D6
// dht.setup(16, DHTesp::DHT11); // Connect DHT sensor to GPIO 16 - D2
//dht.setup(0, DHTesp::DHT11); // Connect DHT sensor to GPIO 0 - D8
dht.setup(4, DHTesp::DHT11); // Connect DHT sensor to GPIO 4 - D4
//dht.begin();
timer.setInterval(2000L, GetTempHumidity);
} // end setup
// only need 1 pin, leave 2 for future
//GetTempHumidity();
//delay(1000);
} // end loop
void GetTempHumidity()
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity();
float temperature = dht.getTemperature();
Serial.print(dht.getStatusString());
Serial.print("\t");
Serial.print(humidity, 1);
Serial.print("\t\t");
Serial.print(temperature, 1);
Serial.print(dht.toFahrenheit(temperature), 1);
Serial.print(dht.computeHeatIndex(temperature, humidity, false), 1);
Serial.println(dht.computeHeatIndex(dht.toFahrenheit(temperature), humidity, true), 1);
Blynk.virtualWrite(V5, humidity);
Blynk.virtualWrite(V6, temperature);
} // end GetTempHumidity
Not sure, do I describe the problem here, after the code?
Board: Arduino D1 wifi with esp8266 0nboard.
Selected board in Arduino IDE: Wemos D1 R1.
Arduino IDE version: 1.8.5
When I comment Blynk.begin and Blynk.run out, it works fine, even with relay connected to D11.
Blynk feedback and version:
[8479] Connected to WiFi
[8479] IP: 192.168.0.102
[8479]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on ESP8266
[8485] Connecting to blynk-cloud.com:80
[8727] <[1D|00|01|00] 3d170bc1986143a69a5bd844b005810b
[8956] >[00|00|01|00|C8]
[8956] Ready (ping: 228ms).
[8957] Free RAM: 48536
[8957] >[14|00|01|00|08]
[8957] >pm[00]6[00]out
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
Blynk server.
Android 8 phone.
Have searched and read up on the watchdog timer, seems delays in the code can cause it, although some say no, delay() incorporates yield() so it should’nt cause a problem.
Do not know if this is true.
Could’nt find what the (1,6) means.
I have tried it without the humidity as well, thought maybe the delay incorporated by the humidity library caused it, but it did not matter.
Should’nt as this library for humidity is for the esp8266
Would appreciate any help.
Thanks.
Peet
