Hello Please, I need help with my project.
Below is the Arduino Code I am using. I do not have any error or warnings but I am having difficulty connecting the blynk app on my iPhone to the Bluetooth device. I see the name under select BLE device but when I click connect it says
“can’t connect. Please retry or choose another device”.
I tried the same code but used an android phone it connected but when I try to run the project is says “wasn’t online yet”.
#include <BlynkSimpleCurieBLE.h>
#include <CurieBLE.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
#include <Servo.h>
//Blynk
char auth[] = "71054d5189654761a50d91f622ad4a7f"; // You should get Auth Token in the Blynk App.
BLEPeripheral blePeripheral;
//Adafruit Motor Shield
Adafruit_MotorShield AFMS = Adafruit_MotorShield(); // Create the motor shield object with the default I2C address
Adafruit_DCMotor *motor1 = AFMS.getMotor(1); // Select which 'port' M1, M2, M3 or M4.
Adafruit_DCMotor *motor2 = AFMS.getMotor(2);
Adafruit_DCMotor *motor3 = AFMS.getMotor(3);
Adafruit_DCMotor *motor4 = AFMS.getMotor(4);
//Servo
Servo servo1; // create servo object to control a servo
Servo servo2;
Servo servo3;
Servo servo4;
int pos1 = 0; // variable to store the servo position
int pos2 = 0;
int pos3 = 0;
int pos4 = 0;
int vDirection = 1;
int vConfiguration = 1;
int vTurn = 0;
int vSpeed = 0;
//######### SETUP ######################################
//Blynk BLE The name your bluetooth service will show up as, customize this if you have multiple devices
blePeripheral.setLocalName("SDROVER");
blePeripheral.setDeviceName("SDROVER");
blePeripheral.setAppearance(384);
Blynk.begin( blePeripheral, auth);
blePeripheral.begin();
Serial.println("Adafruit Motorshield v2 - DC Motor");
AFMS.begin(); // create with the default frequency 1.6KHz
motor1->setSpeed(255); // Set the speed to start, from 0 (off) to 255 (max speed)
motor2->setSpeed(255);
motor3->setSpeed(255);
motor4->setSpeed(255);
//Servo
servo1.attach(3); // attaches the servo on pin 3 to the servo object
servo2.attach(5);
servo3.attach(6);
servo4.attach(9);
//########## LOOP ######################################
blePeripheral.poll();
//######### Subrutines ################################
// This function will set the speed
BLYNK_WRITE(V0)
vSpeed = param.asInt(); // assigning incoming value from pin V1 to a variable
motor1->setSpeed(vSpeed);
motor2->setSpeed(vSpeed);
motor3->setSpeed(vSpeed);
motor4->setSpeed(vSpeed);
Serial.print("V0... vSpeed: ");
Serial.print(vSpeed);
Serial.print(" vDirection: ");
Serial.print(vDirection);
Serial.print(" vTurn: ");
Serial.print(vTurn);
Serial.print(" vConfiguration: ");
Serial.println(vConfiguration);
//Serial.println("V0... vSpeed: " & vSpeed & " vDirection: " + vDirection + " vTurn: " + vTurn + " vConfiguration: " + vConfiguration);
motorStuff();
// Direction
BLYNK_WRITE(V1)
if(pinValue == 1) {
vDirection = 1;
if(pinValue == 0) {
vDirection = 0;
motorStuff();
Serial.println(vDirection);
// Configuration
BLYNK_WRITE(V2)
if(pinValue == 0) {
vConfiguration = 0;
servoPosNormal();
if(pinValue == 1) {
vConfiguration = 1;
servoPosStrafe();
motorStuff();
// Turn
BLYNK_WRITE(V3)
if(pinValue == 1) {
servoPosTurn();
vTurn = 1;
if(pinValue == 0) {
if(vConfiguration == 0) {
servoPosNormal();
else{
servoPosStrafe();
vTurn = 0;
motorStuff();
Serial.println(vTurn);
BLYNK_WRITE(V4)
int vStop = param.asInt(); // assigning incoming value from pin V1 to a variable
if(vStop == 1) {
motor1->run(RELEASE);
motor2->run(RELEASE);
motor3->run(RELEASE);
motor4->run(RELEASE);
void motorStuff() {
if(vSpeed == 0) {
else if(vTurn == 1) {
if(vDirection == 1) {
motor1->run(FORWARD);
motor2->run(BACKWARD);
motor3->run(FORWARD);
motor4->run(BACKWARD);
if(vDirection == 0) {
motor1->run(BACKWARD);
motor2->run(FORWARD);
motor3->run(BACKWARD);
motor4->run(FORWARD);
else if(vConfiguration == 1) {
else if(vConfiguration == 0) {
void servoPosNormal() {
servo1.write(178);
servo2.write(0);
servo3.write(7);
servo4.write(175);
void servoPosStrafe() {
servo1.write(75);
servo2.write(100);
servo3.write(108);
servo4.write(70);
void servoPosTurn() {
servo1.write(115);
servo2.write(65);
servo3.write(65);
servo4.write(115);
//Individual servo functions for calibration
// Servo1
BLYNK_WRITE(V10)
servo1.write(pinValue);
// Servo2
BLYNK_WRITE(V11)
servo2.write(pinValue);
// Servo3
BLYNK_WRITE(V12)
servo3.write(pinValue);
// Servo4
BLYNK_WRITE(V13)
servo4.write(pinValue);
