A command from Node-Red does not affect the hardware, but the app sees it.
- If I tap the button in the app, Node-Red reports the value. The board reports the value.
- If I send the value in Node-Red, the app changes. The board does nothing.
I have tried this with two different Node-Red servers. Am I doing something wrong?
I’m controlling a Wemos D1 Mini Pro with library version 0.6.1 over Wifi. I’m using Node-Red and the node-red-contrib-blynk-ws library version 1.0.3. My app is on iPhone 6s, version 2.26.4. Blynk cloud server.
Code (running on Wemos D1 Mini)
(I’m not using a slider, but I just started with boilerplate code from the example library for this example.)
[Opened issue on github: https://github.com/gablau/node-red-contrib-blynk-ws/issues/22]
http://twitter.com/blynk_app
This sketch shows how to read values from Virtual Pins
App project setup:
Slider widget (0...100) on Virtual Pin V1
char auth[] = "M...t";
char ssid[] = "...";
char pass[] = "...";
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
Serial.println("Blynk Write V1");
Serial.println(String(pinValue));
// process received value
Serial.println();
Serial.println("I'm a machine!");
Serial.println("Setup finished.");
Node-Red
"id": "591c3a35.6ec74c",
"type": "tab",
"label": "Blynk Test",
"disabled": false,
"info": ""
"id": "ec174547.a1436",
"type": "inject",
"z": "591c3a35.6ec74c",
"name": "",
"topic": "",
"payload": "1",
"payloadType": "str",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 110,
"y": 120,
"wires": [
"9f176979.26d2c8"
"id": "6f5f2860.a8041",
"type": "inject",
"name": "",
"topic": "",
"payload": "0",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 110,
"y": 160,
"wires": [
"9f176979.26d2c8"
"id": "9f176979.26d2c8",
"type": "blynk-ws-out-write",
"name": "Sump Pump - Northeast - V1",
"pin": "1",
"pinmode": 0,
"client": "18828803.811b1",
"x": 360,
"y": 160,
"wires": []
"id": "932d23a1.e5f3f",
"type": "blynk-ws-in-write",
"name": "",
"pin": "1",
"pin_all": 0,
"x": 310,
"y": 100,
"wires": [
"393f84f9.480164"
"id": "393f84f9.480164",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"x": 480,
"y": 100,
"wires": []
"id": "18828803.811b1",
"type": "blynk-ws-client",
"z": "",
"name": "Sump Pump - Northeast",
"path": "ws://blynk-cloud.com/websockets",
"key": "M...t",
"dbg_all": false,
"dbg_read": false,
"dbg_write": true,
"dbg_notify": false,
"dbg_mail": false,
"dbg_prop": false,
"dbg_sync": false,
"dbg_bridge": false,
"dbg_low": false,
"dbg_pins": "",
"multi_cmd": false,
"proxy_type": "no",
"proxy_url": "",
"enabled": true
