Any updates on official Arduino GIGA R1 WiFi support?
I’ve seen the older threads about the Arduino GIGA R1 WiFi (STM32H7) not being supported by Blynk:
It still isn’t listed under the officially supported boards, and I was wondering if there’s been any update or plan to add official support for it.
Thanks!
— Abdala
I’ve just signed up for Blynk and started my first project so I’m not familiar with their services yet. What are the benefits of official support? I would guess initial setup is much faster but I’m curious what else I’m missing out on by using a GIGA.
I was able to get connected by using this sketch below (I removed my SSID info), next step will be setting up datastreams.
Thanks.
#define SECRET_SSID "router"
#define SECRET_PASS "password"
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID           "TMPL2M44KM0W3"
#define BLYNK_TEMPLATE_NAME         "Quickstart Template"
#define BLYNK_AUTH_TOKEN            "Rm2k8CrWbwebIBeNx_a85u6uSnSg7cx5"
#include <WiFi.h>
#include <BlynkSimpleWifi.h>
char ssid[] = " ";        // your network SSID (name)
char pass[] = " ";
int status = WL_IDLE_STATUS;     // the WiFi radio's status
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
  // Set incoming value from pin V0 to a variable
  int value = param.asInt();
  // Update state
  Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V3, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  Blynk.virtualWrite(V2, millis() / 1000);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the data:
  Serial.print("You're connected to the network");
  printCurrentNet();
  printWifiData();
  //Blynk Stuff
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
  //timer.setInterval(1000L, myTimerEvent);
  //printCurrentNet();
  //Blynk Stuff
  // to avoid delay() function!
void printWifiData() {
  // print your board's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
  Serial.println();
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
  Serial.println();
