More info. NB. This only happens with the beta version. Not on the current version. It’s looking like the issue is confined to widgets on screens under a tile.
My project starts off with a tab at the top with the first tab being all my tiles. The other tabs have screens with widgets and these widgets are OK. i.e. screens and widgets are not under a tile.
But now look what happens when I execute a screen dump of the above screen, save the dump to drop box, exit and default return to the blynk app :). Magic. Don’t worry about the hall, bathroom and en-suite. They have no data anyway. So this scenario has forced the widgets to be populated by server data. No other action can do this.
The widget setup in the application and/or the home screen? I’ll just do one widget first. The value label.
I’m trying to understand this. My terminology is not right. Do I understand that the home screen widgets should update ok if the project is not loaded as an active app (but logged in), loaded and in background and loaded and in foreground
If you are saying that it needs to be active and either in foreground or background then let me test again. My understanding was that if you were logged in and not active then it should update. This is how I have tested it.
It should had been available, had you seen ‘update’ button or ‘updated’ notification? Sometimes new builds takes more time to be loaded. In any case you can send me a log even for this issue - I’ll check what’s going on.
@BlynkAndroidDev. Tried again but still not seeing a fix. I’m not seeing how I can zero the logs. Can’t find info on the forum. Can you tell me then I’ll email them yo you.
Ok logs emailed to you. I still need to retest the home screen widget based on what you told me yesterday. I think my expectations were different to the reality.
We released 2.27.1 to production and uploaded new beta 2.27.1 (difference with production is only in enabled logs and multi-window support for Android 7 and later), changes from previous version:
Segmented Control widget: support for tags selection as a target
Notification widget: better support on Android 8.0 and later
