Rahul
July 11, 2015, 7:46am
1
Continuing the discussion from Blynk Joystick widget for Quadcopter control :
You can add widgets in the app and arrange them in any way. This is one of the Blynk powers
We use TCP/IP for connection. The average size of 1 packet is ~14bytes.
You can take a look on our libraries and server code here: blynkkk (Blynk IoT platform) · GitHub
Continuing the discussion from ESP8266 as access point :
Hi. Reading the thread once again, I understand your problem.Unfortunately this scenario won’t work right now, as the App uses SSL connection to the server.So it will never connect (Arduino for ESP has only TCP server as of writing).
just to be clear, the app uses SSL connection while arduino sketch uses TCP to connect to cloud?
Im sorry, but Im an absolute beginner… thanks for your patience
Dmytro
July 11, 2015, 9:11am
2
Correct. But in case of USB connection hardware connected over SSL also.
