Thanks to the recent addition of the Time Input Widget, I was able to rescue this particular project from the dust bin. I created it last July to be a simple way to demonstrate the Blynk apps ability to control ESP8266 I/O pins directly, using the ESP’s native 10 bit PWM to control 8 Meanwell LDD-H series Led Drivers. Now that some time has passed and the Time Input widget has become available, I realized that this project could be re-vamped into an actual standalone Aquarium lighting controller. I’ve designed and built dozens of similar projects using other commercially available aquarium lighting controllers over the last few years, but this one is special… thanks to BLYNK.
Mind you, I’m not a coder, I’m not even a Hardware Engineer, I’m just a guy that’s passionate for DIY with just enough tenacity to learn new things. My coding skills suck and I make the occasional mistake with my hardware designs, but I keep at it until it works. This particular project functions just fine hardware wise, but the software needs a little help. The software works fine as it is now, but crashes if WiFiManager is included. I’m still trying to sort that issue out.
Here’s a photo of the bare PcB-
Here’s a photo of the PcB with all the surface mounted components soldered on-
Here’s a photo of the completed PcB with most of it’s secondary components mounted.
This PcB uses the Wemos D1 Mini for the brains of the operation. There’s an Atmega 328p -AU soldered to the board that’s programmed to read any of the ESP’s 8 outputs and convert the signal to a 25Khz copy of the original. This 25Khz signal is then used to drive up to 3 PC cooling fans without the annoying whine normally associated with using low frequency PWM.
The Meanwell LDD-H constant current Led drivers are fed from a 48 - 56V power supply. The high voltage needed to drive long strings of leds is also fed to a couple Meanwell SCW08C-12 “DC to DC” converters. The resulting 12V is used to power the PC cooling fans and feed a 5V/1amp regulator connected to the ESP’s and Atmega 328’s 5V input. From my testing, the 5V supply appears to be more than adequate to drive the ESP’s 3V3 regulator.
Here’s the code that I’m using. Mind you, for now the WiFiManager portion needs to stay commented out.
I know this code could definitely be condensed into Arrays and what not, so don’t be too cruel…I haven’t learned to do that yet. It’s overly cumbersome but it does work.
EXPERIMENTAL WEMOS D1 MINI (ESP8266) ANALOG DIMMING CODE WITH 8 CHANNELS.
For Use with the O2Surplus ESP8266 8 Channel PcB.
//#include <FS.h> // needs to be first in includes.
#include <ArduinoOTA.h>
#include <TimeLib.h>
#include <WidgetRTC.h>
//included libraries for WiFiManager - AutoConnectWithFSParameters
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx";
// Your WiFi credentials. Set password to "" for open networks.
char ssid[] = "xxxxxxxx";
char pass[] = "xxxxxxxx";
char blynk_token[34] = "YOUR_BLYNK_TOKEN";//added from WiFiManager - AutoConnectWithFSParameters
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
char Date[16];
char Time[16];
long startseconds = 0; // start time in seconds
long stopseconds = 0; // stop time in seconds
long nowseconds = 0; // time now in seconds
bool isFirstConnect = true;
int fadetime = 0;
long fadetimeseconds = 0;
long fadetimemillis = 0;
int minPWM = 1;// variable for min PWM value. keep at 1 to avoid crashing the ledFade()
byte fadeIncrement = 1; //How smooth to fade? Uses all 4095 steps available.
int maxPWM0 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM1 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM2 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM3 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM4 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM5 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM6 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM7 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int currentFadePosition0 = 0;// don't change this!
int currentFadePosition1 = 0;// don't change this!
int currentFadePosition2 = 0;// don't change this!
int currentFadePosition3 = 0;// don't change this!
int currentFadePosition4 = 0;// don't change this!
int currentFadePosition5 = 0;// don't change this!
int currentFadePosition6 = 0;// don't change this!
int currentFadePosition7 = 0;// don't change this!
unsigned long previousFadeMillis0;// millis() timing Variable, just for fading
unsigned long previousFadeMillis1;// millis() timing Variable, just for fading
unsigned long previousFadeMillis2;// millis() timing Variable, just for fading
unsigned long previousFadeMillis3;// millis() timing Variable, just for fading
unsigned long previousFadeMillis4;// millis() timing Variable, just for fading
unsigned long previousFadeMillis5;// millis() timing Variable, just for fading
unsigned long previousFadeMillis6;// millis() timing Variable, just for fading
unsigned long previousFadeMillis7;// millis() timing Variable, just for fading
long stepWaitTime0 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime1 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime2 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime3 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime4 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime5 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime6 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime7 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
int desiredledLevel0 = 0;
int desiredledLevel1 = 0;
int desiredledLevel2 = 0;
int desiredledLevel3 = 0;
int desiredledLevel4 = 0;
int desiredledLevel5 = 0;
int desiredledLevel6 = 0;
int desiredledLevel7 = 0;
#define led0 D1
#define led1 D2
#define led2 D3
#define led3 D4
#define led4 D5
#define led5 D6
#define led6 D7
#define led7 D8
WidgetRTC rtc;
// divide your desired dimming time duration(in millis) by the maxPWM variable value / fadeIncrement variable value to
// get the stepWaitTime variable value needed.
// EXAMPLE: maxPWM of 1023/fadeIncrement of 1 to dim over 1 hour is a stepWaitTime of 3,519 millis.
void setLed() {
stepWaitTime0 = (fadetimemillis / maxPWM0);
stepWaitTime1 = (fadetimemillis / maxPWM1);
stepWaitTime2 = (fadetimemillis / maxPWM2);
stepWaitTime3 = (fadetimemillis / maxPWM3);
stepWaitTime4 = (fadetimemillis / maxPWM4);
stepWaitTime5 = (fadetimemillis / maxPWM5);
stepWaitTime6 = (fadetimemillis / maxPWM6);
stepWaitTime7 = (fadetimemillis / maxPWM7);
void ledFade0(unsigned long thisMillis0) {
if (nowseconds < startseconds) {
currentFadePosition0 = minPWM;
if (nowseconds > startseconds && nowseconds < stopseconds) {
// is it time to start the Sunrise?
// if not, nothing happens
if (thisMillis0 - previousFadeMillis0 >= stepWaitTime0) {
currentFadePosition0 = currentFadePosition0 + fadeIncrement;
if (currentFadePosition0 >= maxPWM0) {
// At max limit stop the fade
currentFadePosition0 = maxPWM0;
// put actionable () here.
analogWrite(led0, currentFadePosition0);
// reset millis for the next iteration (fade timer only)
previousFadeMillis0 = thisMillis0;
if (nowseconds > stopseconds) {
// is it time to start the Sunset yet?
currentFadePosition0 = currentFadePosition0 - fadeIncrement;
if (currentFadePosition0 <= minPWM) {
// At min limit stop the fade
void ledFade1(unsigned long thisMillis1) {
currentFadePosition1 = minPWM;
if (thisMillis1 - previousFadeMillis1 >= stepWaitTime1) {
currentFadePosition1 = currentFadePosition1 + fadeIncrement;
if (currentFadePosition1 >= maxPWM1) {
currentFadePosition1 = maxPWM1;
analogWrite(led1, currentFadePosition1);
previousFadeMillis1 = thisMillis1;
currentFadePosition1 = currentFadePosition1 - fadeIncrement;
if (currentFadePosition1 <= minPWM) {
void ledFade2(unsigned long thisMillis2) {
currentFadePosition2 = minPWM;
if (thisMillis2 - previousFadeMillis2 >= stepWaitTime2) {
currentFadePosition2 = currentFadePosition2 + fadeIncrement;
if (currentFadePosition2 >= maxPWM2) {
currentFadePosition2 = maxPWM2;
analogWrite(led2, currentFadePosition2);
previousFadeMillis2 = thisMillis2;
currentFadePosition2 = currentFadePosition2 - fadeIncrement;
if (currentFadePosition2 <= minPWM) {
void ledFade3(unsigned long thisMillis3) {
currentFadePosition3 = minPWM;
if (thisMillis3 - previousFadeMillis3 >= stepWaitTime3) {
currentFadePosition3 = currentFadePosition3 + fadeIncrement;
if (currentFadePosition3 >= maxPWM3) {
currentFadePosition3 = maxPWM3;
analogWrite(led3, currentFadePosition3);
previousFadeMillis3 = thisMillis3;
currentFadePosition3 = currentFadePosition3 - fadeIncrement;
if (currentFadePosition3 <= minPWM) {
void ledFade4(unsigned long thisMillis4) {
currentFadePosition4 = minPWM;
if (thisMillis4 - previousFadeMillis4 >= stepWaitTime4) {
currentFadePosition4 = currentFadePosition4 + fadeIncrement;
if (currentFadePosition4 >= maxPWM4) {
currentFadePosition4 = maxPWM4;
analogWrite(led4, currentFadePosition4);
previousFadeMillis4 = thisMillis4;
currentFadePosition4 = currentFadePosition4 - fadeIncrement;
if (currentFadePosition4 <= minPWM) {
void ledFade5(unsigned long thisMillis5) {
currentFadePosition5 = minPWM;
if (thisMillis5 - previousFadeMillis5 >= stepWaitTime5) {
currentFadePosition5 = currentFadePosition5 + fadeIncrement;
if (currentFadePosition5 >= maxPWM5) {
currentFadePosition5 = maxPWM5;
analogWrite(led5, currentFadePosition5);
previousFadeMillis5 = thisMillis5;
currentFadePosition5 = currentFadePosition5 - fadeIncrement;
if (currentFadePosition5 <= minPWM) {
void ledFade6(unsigned long thisMillis6) {
currentFadePosition6 = minPWM;
if (thisMillis6 - previousFadeMillis6 >= stepWaitTime6) {
currentFadePosition6 = currentFadePosition6 + fadeIncrement;
if (currentFadePosition6 >= maxPWM6) {
currentFadePosition6 = maxPWM6;
analogWrite(led6, currentFadePosition6);
previousFadeMillis6 = thisMillis6;
currentFadePosition6 = currentFadePosition6 - fadeIncrement;
if (currentFadePosition6 <= minPWM) {
void ledFade7(unsigned long thisMillis7) {
currentFadePosition7 = minPWM;
if (thisMillis7 - previousFadeMillis7 >= stepWaitTime7) {
currentFadePosition7 = currentFadePosition7 + fadeIncrement;
if (currentFadePosition7 >= maxPWM7) {
currentFadePosition7 = maxPWM7;
analogWrite(led7, currentFadePosition7);
previousFadeMillis7 = thisMillis7;
currentFadePosition7 = currentFadePosition7 - fadeIncrement;
if (currentFadePosition7 <= minPWM) {
// Digital clock display of the time
void clockDisplay()
// You can call hour(), minute(), ... at any time
// Please see Time library examples for details
String currentDate = String(month()) + " " + day() + " " + year();
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
Serial.print("Time =");
Serial.println(currentTime);
Serial.print("Nowseconds =");
Serial.println(nowseconds);
Serial.print("Start = ");
Serial.println(startseconds);
Serial.print("Stop = ");
Serial.println(stopseconds);
Serial.println();
Blynk.virtualWrite(V8, currentTime);
BLYNK_WRITE(V0) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel0 = param.asInt();// channel 1
maxPWM0 = map(desiredledLevel0, 0, 100, minPWM, 1023);
BLYNK_WRITE(V1) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel1 = param.asInt();// channel 2
maxPWM1 = map(desiredledLevel1, 0, 100, minPWM, 1023);
BLYNK_WRITE(V2) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel2 = param.asInt();// channel 3
maxPWM2 = map(desiredledLevel2, 0, 100, minPWM, 1023);
BLYNK_WRITE(V3) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel3 = param.asInt();// channel 4
maxPWM3 = map(desiredledLevel3, 0, 100, minPWM, 1023);
BLYNK_WRITE(V4) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel4 = param.asInt();// channel 5
maxPWM4 = map(desiredledLevel4, 0, 100, minPWM, 1023);
BLYNK_WRITE(V5) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel5 = param.asInt();// channel 6
maxPWM5 = map(desiredledLevel5, 0, 100, minPWM, 1023);
BLYNK_WRITE(V6) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel6 = param.asInt();// channel 7
maxPWM6 = map(desiredledLevel6, 0, 100, minPWM, 1023);
BLYNK_WRITE(V7) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel7 = param.asInt();// channel 8
maxPWM7 = map(desiredledLevel7, 0, 100, minPWM, 1023);
BLYNK_WRITE(V9) {// slider widget to set the led fade duration up tp 3 hours.
fadetime = param.asInt();
fadetimeseconds = map(fadetime, 0, 180, 1, 10800);// 3 hour fade duration is max
fadetimemillis = map(fadetime, 0, 180, 1, 10800000);// 3 hour fade duration is max
Serial.print("Fade Time in seconds =");
Serial.println(fadetimeseconds);
void activetoday() { // check if schedule should run today
if (year() != 1970) {
Blynk.syncVirtual(V3); // sync timeinput widget
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
BLYNK_WRITE(V10) {
TimeInputParam t(param);
Serial.print("Checked schedule at: ");
Serial.println(Time);
int dayadjustment = -1;
if (weekday() == 1) {
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if (t.isWeekdaySelected((weekday() + dayadjustment))) { //Time library starts week on Sunday, Blynk on Monday
Serial.println("Schedule ACTIVE today");
startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
if (nowseconds >= startseconds) {
if (nowseconds <= startseconds + 90) { // 90s on 60s timer ensures 1 trigger command is sent
// code here
else {
Serial.println("Relay not on");// nothing more to do here, waiting for relay to be turned on later today
stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
if (nowseconds >= stopseconds) {
if (nowseconds <= stopseconds + 90) {
// code here
else {
if (nowseconds >= startseconds) { // only show if motor has already started today
Serial.println("Relay is still ON");
// nothing more to do here, waiting for motor to be turned off later today
else {
Serial.println("Schedule INACTIVE today");
// nothing to do today, check again in 1 minutes time
Serial.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if (Blynk.connect()) {
BLYNK_LOG("Reconnected");
else {
BLYNK_LOG("Not reconnected");
ArduinoOTA.begin();
// Wait until connected
//The following code is borrowed from WiFiManager
//clean FS, for testing
//SPIFFS.format();
//read configuration from FS json
Serial.println("mounting FS...");
if (SPIFFS.begin()) {
Serial.println("mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("failed to load json config");
Serial.println("failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 34);
Serial.println(blynk_token);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
//set config save notify callback
wifiManager.setSaveConfigCallback(saveConfigCallback);
//add all your parameters here
wifiManager.addParameter(&custom_blynk_token);
//reset settings - for testing
//wifiManager.resetSettings();
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep
//in seconds
wifiManager.setTimeout(180);
//fetches ssid and pass and tries to connect
//if it does not connect it starts an access point with the specified name
//here "8 CH LED CONTROL"
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("8 CH LED CONTROL")) {
Serial.println("failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("8 CH LED CONTROL connected :)");
//read updated parameters
strcpy(blynk_token, custom_blynk_token.getValue());
//save the custom parameters to FS
if (shouldSaveConfig) {
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
Serial.println("local ip");
Blynk.connect();
Blynk.config(blynk_token);
if (!blynk_token)
Serial.println("Failed to connect to Blynk server");
wifiManager.resetSettings();// reset all settings and spool up the "TERRA HVAC" AP again.
Serial.println("Done");
Blynk.notify("8 Ch Wemos D1 Mini LDD-H led driver PcB Connected successfully");
rtc.begin();
timer.setInterval(1000L, setLed);
timer.setInterval(1000L, clockDisplay); // digital time displayed every second
timer.setInterval(60000L, activetoday); // check every minute if schedule should run today
timer.setInterval(60000L, reconnectBlynk); // check every 60s if still connected to server
Blynk.syncAll();
ArduinoOTA.handle();
if (Blynk.connected()) {
// get the current time, for this time around loop
// all millis() timer checks will use this time stamp
unsigned long currentMillis0 = millis();
ledFade0(currentMillis0);
unsigned long currentMillis1 = millis();
ledFade1(currentMillis1);
unsigned long currentMillis2 = millis();
ledFade2(currentMillis2);
unsigned long currentMillis3 = millis();
ledFade3(currentMillis3);
unsigned long currentMillis4 = millis();
ledFade4(currentMillis4);
unsigned long currentMillis5 = millis();
ledFade5(currentMillis5);
unsigned long currentMillis6 = millis();
ledFade6(currentMillis6);
unsigned long currentMillis7 = millis();
ledFade7(currentMillis7);
Here’s what my Blynk Dash board look like-
Front tab-
Back Tab-
Any comments are welcome!
