Looking for some help with my project. I had the time inputs working but now the relays arnt triggered at the set times and the leds do some strange things. like when you move the slider for the brightness, the leds brighten and dim several times on the was to max (a value of 100). its almost like the leds only dim from say 1 to 20 then starts back at 2 again. It was my understanding this was the correct way to go with multiple time inputs but its not working.
Could anyone give me and pointers and some understanding as to where i have gone wrong?
Should i add some check flags on each timer as i feel that would make it a little more stable and help to not miss a activation?
thanks in advance
Adam.
#include <Nextion.h> // Include the nextion library (the official one) https://github.com/itead/ITEADLIB_Arduino_Nextion
// Make sure you edit the NexConfig.h file on the library folder to set the correct serial port for the display.
// By default it's set to Serial1, which most arduino boards don't have.
// Change "#define nexSerial Serial1" to "#define nexSerial Serial" if you are using arduino uno, nano, etc.
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h> // This part is for Ethernet stuff
#define W5100_CS 10
#define SDCARD_CS 4
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = "d27bf6f0a098498a81a5c65dab79b851"; // Put your Auth Token here.
WidgetRTC rtc;
//Temperature
#include <OneWire.h> // Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
//Get DallasTemperature Library here: http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS 48// DS18B20 on arduino pin
DallasTemperature DS18B20(&oneWire);
// This function will run every time Blynk connection is established
DeviceAddress Probe01 = { 0x28, 0xFF, 0x2D, 0x5A, 0xC4, 0x17, 0x05, 0xEF };
DeviceAddress Probe02 = { 0x28, 0x1F, 0x12, 0x77, 0x91, 0x0A, 0x02, 0x68 };
float tanktemp;
float sumptemp;
BLYNK_CONNECTED() {
rtc.begin();
// Request Blynk server to re-send latest values for all pins
Blynk.syncAll();
//ATO switches and relay
byte lowWaterPin = 6; // Goes LOW when water below switch
byte highWaterPin = 7; // Goes LOW when water below switch
byte pumpPin = 8; // Relay to control the water pump
unsigned long maxRunTime = 60 * 1000L; // pump on for max of one minute
unsigned long minOffTime = 60 * 60 * 1000L; // pump must be off for at least one hour
unsigned long switchDebounceTime = 3 * 1000L; // Switch must be activated for at least 3 seconds.
unsigned long lastPumpTime = 0;
unsigned long lastLowWaterDetectTime = 0;
unsigned long currentMillis;
boolean lastLowWaterState = HIGH;
boolean pumpRunning = false;
int relayPin = 49;// Heater on ssr1
int relay2Pin = 28;// Cooling to 16ch relay board relay 7 on the board
int relay3Pin = 22;// return pump on relay 1 on the board
int relay4Pin = 23;// Skimmer on relay 2 on the board
int relay5Pin = 24;// Reactor on relay 3 on the board
int relay6Pin = 25;// t5s on relay 4 on the board
int relay7Pin = 26;//
int relay8Pin = 27;//
int wave1Pin = 47;// Wave maker on ssr2
int wave2Pin = 46;// Wavemaker 2 on ssr3
float desiredTemp = 26;// Set this to your desired temp
float tempDiff = 1;// This variable provides a small +/- temp differential that will prevent constant relay switching.
bool tempAlarmFlag = false; //flag to alarm, and avoid multiple Notification
bool faultyProbeFlag = false; //flag to alarm, and avoid multiple Notification
float lowAlarm = NAN;
float highAlarm = NAN;
int onsec =3; // Global variable used in Slider widget and runEveryMinute()
int offsec=3; // Global variable used in Slider widget and runEveryMinute()
int x;
int y;
int CounterOn = 0;
int CounterOff = 0;
int ledStatus = 0;
int wavesw = 1;// Wave maker Onoff Button
int heatersw = 1;// Heater Onoff Button
int coolingsw = 1;// Cooling switch
int CurrentPage = 0; // Create a variable to store which page is currently loaded
char Date[16];
char Time[16];
long startseconds = 0; // start time in seconds
long stopseconds = 0; // stop time in seconds
long nowseconds = 0; // time now in seconds
int fadetime = 0;
long fadetimeseconds = 0;
long fadetimemillis = 0;
int minPWM = 1;// variable for min PWM value. keep at 1 to avoid crashing the ledFade()
byte fadeIncrement = 1; //How smooth to fade? Uses all 4095 steps available.
int maxPWM0 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int maxPWM1 = 0; // variable for max PWM value attached to BLYNK Virtual pin.
int currentFadePosition0 = 0;// don't change this!
int currentFadePosition1 = 0;// don't change this!
unsigned long previousFadeMillis0;// millis() timing Variable, just for fading
unsigned long previousFadeMillis1;// millis() timing Variable, just for fading
long stepWaitTime0 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
long stepWaitTime1 = 0; //How long to watch the clock before incrementing to the next step. (time in milliseconds)
int desiredledLevel0 = 0;
int desiredledLevel1 = 0;
int desiredledLevel2 = 0;
int desiredledLevel3 = 0;
int desiredledLevel4 = 0;
int desiredledLevel5 = 0;
int desiredledLevel6 = 0;
int desiredledLevel7 = 0;
#define led0 2 // white leds on pin...
#define led1 3 // blue leds on pin...
// LED light control
void setLed() {
stepWaitTime0 = (fadetimemillis / maxPWM0);
stepWaitTime1 = (fadetimemillis / maxPWM1);
void ledFade0(unsigned long thisMillis0) {
if (nowseconds < startseconds) {
currentFadePosition0 = minPWM;
if (nowseconds > startseconds && nowseconds < stopseconds) {
// is it time to start the Sunrise?
// if not, nothing happens
if (thisMillis0 - previousFadeMillis0 >= stepWaitTime0) {
currentFadePosition0 = currentFadePosition0 + fadeIncrement;
if (currentFadePosition0 >= maxPWM0) {
// At max limit stop the fade
currentFadePosition0 = maxPWM0;
// put actionable () here.
analogWrite(led0, currentFadePosition0);
// reset millis for the next iteration (fade timer only)
previousFadeMillis0 = thisMillis0;
if (nowseconds > stopseconds) {
// is it time to start the Sunset yet?
currentFadePosition0 = currentFadePosition0 - fadeIncrement;
if (currentFadePosition0 <= minPWM) {
// At min limit stop the fade
void ledFade1(unsigned long thisMillis1) {
currentFadePosition1 = minPWM;
if (thisMillis1 - previousFadeMillis1 >= stepWaitTime1) {
currentFadePosition1 = currentFadePosition1 + fadeIncrement;
if (currentFadePosition1 >= maxPWM1) {
currentFadePosition1 = maxPWM1;
analogWrite(led1, currentFadePosition1);
previousFadeMillis1 = thisMillis1;
currentFadePosition1 = currentFadePosition1 - fadeIncrement;
if (currentFadePosition1 <= minPWM) {
// Digital clock display of the time
void clockDisplay(){
nowseconds = ((hour() * 3600) + (minute() * 60) + second());
Serial.print("Time =");
Serial.println(currentTime);
// Serial.println(currentDate);
Serial.print("Nowseconds =");
Serial.println(nowseconds);
// Serial.print("Start = ");
// Serial.println(startseconds);
//Serial.print("Stop = ");
// Serial.println(stopseconds);
// Serial.print("fade position0 =");
// Serial.println(currentFadePosition0);
// Serial.println();
// Send time to the App
Blynk.virtualWrite(V0, currentTime);
// Send date to the App
//Blynk.virtualWrite(V2, currentDate);
BLYNK_WRITE(V10) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel0 = param.asInt();// channel 1
maxPWM0 = map(desiredledLevel0, 0, 100, minPWM, 1023);
BLYNK_WRITE(V13) {// slider widget to set the maximum led level from the Blynk App.
desiredledLevel1 = param.asInt();// channel 2
maxPWM1 = map(desiredledLevel1, 0, 100, minPWM, 1023);
BLYNK_WRITE(V14) {// slider widget to set the led fade duration up tp 3 hours.
fadetime = param.asInt();
fadetimeseconds = map(fadetime, 0, 180, 1, 10800);// 3 hour fade duration is max
fadetimemillis = map(fadetime, 0, 180, 1, 10800000);// 3 hour fade duration is max
// Serial.print("Fade Time in seconds =");
// Serial.println(fadetimeseconds);
void activetoday() { // check if schedule should run today
if (year() != 1970) {
Blynk.syncVirtual(V15); // sync led timeinput widget
Blynk.syncVirtual(V16);// sync T5s timeinput widget
sprintf(Date, "%02d/%02d/%04d", day(), month(), year());
BLYNK_WRITE(V58){ //leds relay buton
int ledr = param.asInt(); // Get State of Virtual Button, heater
if (ledr == 1) {
digitalWrite(relay7Pin,LOW);
digitalWrite(relay7Pin,HIGH);
BLYNK_WRITE(V57){ //leds relay buton
if (ledr == 1) {
digitalWrite(relay8Pin,LOW);
digitalWrite(relay8Pin,HIGH);
BLYNK_WRITE(V17){ // t5s button off
int tubes = param.asInt(); // Get State of Virtual Button, Return pump
if (tubes == 1) { // button ON
// Turn as many pins/relays ON as you need
digitalWrite(relay6Pin, LOW);
} else { // button OFF
// Turn as many pins/relays OFF as you need
digitalWrite(relay6Pin, HIGH);
BLYNK_WRITE(V16) { // T5s
TimeInputParam t(param);
int startsecond = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
int stopsecond = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
Serial.println(startsecond);
Serial.println(stopsecond);
Serial.println();
int dayadjustment = -1;
if(weekday() == 1){
dayadjustment = 6; // needed for Sunday Time library is day 1 and Blynk is day 7
if(t.isWeekdaySelected((weekday() + dayadjustment))){ //Time library starts week on Sunday, Blynk on Monday
//Schedule is ACTIVE today
if(nowseconds >= startsecond - 31 && nowseconds <= startsecond + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
Blynk.virtualWrite(V17, 1); // turn on virtual button t5s
Serial.println("Schedule 1 started");
digitalWrite(25, HIGH);// turn t5s relay on
if(nowseconds >= stopsecond - 31 && nowseconds <= stopsecond + 31 ){ // 62s on 60s timer ensures 1 trigger command is sent
Blynk.virtualWrite(V17, 0); // turn OFF virtual vutton t5s
Serial.println("Schedule 1 finished");
digitalWrite(25, LOW);// turn t5s relay off
BLYNK_WRITE(V15) {// set time for leds
Serial.print("Checked schedule at: ");
Serial.println(Time);
if (weekday() == 1) {
dayadjustment = 6; // needed for Sunday, Time library is day 1 and Blynk is day 7
if (t.isWeekdaySelected((weekday() + dayadjustment))) { //Time library starts week on Sunday, Blynk on Monday
Serial.println("Schedule ACTIVE today");
startseconds = (t.getStartHour() * 3600) + (t.getStartMinute() * 60);
if (nowseconds >= startseconds) {
if (nowseconds <= startseconds + 90) { // 90s on 60s timer ensures 1 trigger command is sent
// code here
Blynk.virtualWrite(V57, LOW);// turns LED relay on
Blynk.virtualWrite(V58, HIGH);// turns fuge light off
else {
Serial.println("Relay not on");// nothing more to do here, waiting for relay to be turned on later today
stopseconds = (t.getStopHour() * 3600) + (t.getStopMinute() * 60);
if (nowseconds >= stopseconds) {
if (nowseconds <= stopseconds + 90) {
// code here
Blynk.virtualWrite(V58, LOW);// turns fuge light on
Blynk.virtualWrite(V57, HIGH);// turns LED relay off
else {
if (nowseconds >= startseconds) { // only show if motor has already started today
Serial.println("Relay is still ON");
// nothing more to do here, waiting for motor to be turned off later today
else {
Serial.println("Schedule INACTIVE today");
// nothing to do today, check again in 1 minutes time
Serial.println();
void reconnectBlynk() {
if (!Blynk.connected()) {
if (Blynk.connect()) {
BLYNK_LOG("Reconnected");
else {
BLYNK_LOG("Not reconnected");
//WAVEMAKERS CONTROLE
BLYNK_WRITE(V4){ // wave on time slider
x = param.asInt();
onsec = x;
BLYNK_WRITE(V7){ // wave Off time slider
y = param.asInt(); // set variable as Slider value
offsec = y;
void wavecontrol()
if(wavesw == 1)
if ((CounterOn > 0) && (ledStatus == 0) && (wavesw == 1))
digitalWrite(wave1Pin,HIGH); //write to pin to turn the LED on.
digitalWrite(wave2Pin,LOW);
Serial.print(": LED on\n");
ledStatus = 1;
CounterOff = 0;
if ((CounterOn > 0) && (ledStatus == 1))
CounterOn = (CounterOn - 1);
if ((CounterOff == 0) && (CounterOn == 0) && (ledStatus == 1) && (wavesw == 1))
CounterOff = onsec;
if ((CounterOff > 0) && (ledStatus == 1))
digitalWrite(wave1Pin,LOW); //write to pin to turn wave1 off
digitalWrite(wave2Pin,HIGH);//write to pin to turn wave2 on
ledStatus = 0;
CounterOn = 0;
if ((CounterOff > 0) && (ledStatus == 0))
CounterOff = (CounterOff - 1);
if ((CounterOff == 0) && (CounterOn == 0) && (ledStatus == 0))
CounterOn = offsec+1;
BLYNK_WRITE(V6) // wavemakers
int wavesw = param.asInt(); // Get State of Virtual Button, wave makers
if (wavesw == 1) {
wavecontrol();
Blynk.virtualWrite(V4,0);
Blynk.virtualWrite(V7,0);
//TEMPERATURE CONTROL
BLYNK_WRITE(V8){
int heatersw = param.asInt(); // Get State of Virtual Button, heater
if (heatersw == 1) {
Heater();
digitalWrite(relayPin,LOW);
BLYNK_WRITE(V9){
int coolingsw = param.asInt(); // Get State of Virtual Button, cooling
if (coolingsw == 1) {
Cooler();
digitalWrite(relay2Pin,HIGH);
BLYNK_WRITE(V11)
//reads the setppoint
desiredTemp = param.asFloat();
BLYNK_WRITE(V12)
//reads the differential
tempDiff = param.asFloat();
BLYNK_WRITE(V32){
//reads low alarm
lowAlarm = param.asFloat();
BLYNK_WRITE(V33){
//reads high alarm
highAlarm = param.asFloat();
void relaysOn()
digitalWrite(relay4Pin, LOW);
Blynk.virtualWrite(V2, HIGH);
digitalWrite(relay5Pin, LOW);
Blynk.virtualWrite(V3, HIGH);
Blynk.virtualWrite(V6,HIGH);// wavemakers
Blynk.syncVirtual(V6); // Trigger the associated function for V6 as if you had touched the widget in the App
void take_temp_readings() {
//Serial.print("Number of Devices found on bus = ");
//Serial.println(DS18B20.getDeviceCount());
//Serial.print("Getting temperatures... ");
//Serial.println();
DS18B20.requestTemperatures(); // Command all devices on bus to read temperature
tanktemp = DS18B20.getTempCByIndex(0);
sumptemp = DS18B20.getTempCByIndex(1);
if (tanktemp == -127.00)
Serial.println("Error getting temperature ");
void send_data_to_blynk()
Blynk.virtualWrite(5, tanktemp); // send tank temp to virtual pin 5
Blynk.virtualWrite(56, sumptemp);// send sump temp to virtual pin 56
Serial.println("Data sent to Blynk");
//check alarms;
if (isnan(tanktemp)){
if (Blynk.connected() && !faultyProbeFlag)
Blynk.notify("Probe disconnected");
Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", "Probe disconnected");
faultyProbeFlag = true;
else if (tanktemp < lowAlarm && !tempAlarmFlag){
Blynk.notify(String(tanktemp) + "ºC Low temp alarm");
Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", (String(tanktemp) + "ºC Low temp alarm"));
tempAlarmFlag = true;
else if (tanktemp > highAlarm && !tempAlarmFlag){
Blynk.notify(String(tanktemp) + "ºC High temp alarm");
Blynk.email("A.bundy1995@hotmail.co.uk", "Aquaruim Controler Alert", (String(tanktemp) + "ºC High temp alarm"));
else if (tanktemp > lowAlarm && tanktemp < highAlarm)
else faultyProbeFlag = false;
void ATOcontrol()
boolean lowWaterState = digitalRead(lowWaterPin);
boolean highWaterState = digitalRead(highWaterPin);
if(lowWaterState != lastLowWaterState){
lastLowWaterDetectTime = currentMillis;
if (pumpRunning) { // if the pump is on then let's see if we should turn it off yet
if ((highWaterState == HIGH) || (currentMillis - lastPumpTime >= maxRunTime)){
digitalWrite(pumpPin, LOW);
lastPumpTime = currentMillis;
else { // pump is not running, see if we need to turn it on
if((lowWaterState == LOW) && (currentMillis - lastLowWaterDetectTime >= switchDebounceTime) && (currentMillis - lastPumpTime > minOffTime)){ // switch is low and has been for at least 3 seconds
digitalWrite(pumpPin, HIGH);
pumpRunning = true;
lastLowWaterState = lowWaterState;
void Heater()
//if sensor not sending temperature turn relay OFF for safety
if (isnan(tanktemp)) {
digitalWrite(relayPin, LOW);
if ((tanktemp < desiredTemp - tempDiff ) && (heatersw == 1))
digitalWrite(relayPin, HIGH);
if (tanktemp > desiredTemp )
}//--(end Heater )---
void Cooler()
if ((tanktemp > desiredTemp - tempDiff ) && (coolingsw == 1))
digitalWrite(relay2Pin, LOW);
if (tanktemp < desiredTemp )
digitalWrite(relay2Pin, HIGH);
}//--(end Cooler )---
// BUTTON INPUTS
BLYNK_WRITE(V3){ // Reactor button off
int reactor = param.asInt(); // Get State of Virtual Button, Return pump
if (reactor == 1) { // button ON
digitalWrite(relay5Pin, HIGH);
BLYNK_WRITE(V2){ // Skimmer button off
int skimmer = param.asInt(); // Get State of Virtual Button, Return pump
if (skimmer == 1) { // button ON
digitalWrite(relay4Pin, HIGH);
BLYNK_WRITE(V1){ // Return pump button off
int value = param.asInt(); // Get State of Virtual Button, Return pump
if (value == 1) { // button ON
digitalWrite(relay3Pin, LOW);
// bt0.setValue(&number5);
timer.setTimeout(30000, relaysOn);
digitalWrite(relay3Pin, HIGH);
Blynk.virtualWrite(V2, LOW);// Skimmer
Blynk.virtualWrite(V3, LOW);// Reactor
Blynk.virtualWrite(V6, LOW);// Wavemakers
Blynk.virtualWrite(V8, LOW);// Heating
Blynk.virtualWrite(V9, LOW);// Cooling
Blynk.syncVirtual(V9);
BLYNK_WRITE(V38){ // feed button to turn relays off for set time then back on again
if (value == 1) { // button Pressed
timer.setTimeout(420000L, relaysOn);// wait for 7 mins before turning everything back on.
Blynk.virtualWrite(V1, HIGH);
Blynk.syncVirtual(V1);
void setup() /****** SETUP: RUNS ONCE ******/
Serial.begin(9600); // start serial port to show results
setSyncInterval(10 * 60); // Sync interval in seconds (10 minutes)
// run timer every minute to check for led On/Off action
DS18B20.begin(); // Initialize the Temperature measurement library
// set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
DS18B20.setResolution(Probe01, 12);
DS18B20.setResolution(Probe02,12);
pinMode(relayPin, OUTPUT);
pinMode(relay2Pin, OUTPUT);
pinMode(relay3Pin, OUTPUT);
pinMode(relay4Pin, OUTPUT);
pinMode(relay5Pin, OUTPUT);
pinMode(wave1Pin, OUTPUT);
pinMode(wave2Pin, OUTPUT);
pinMode(relay6Pin, OUTPUT);// t5s declaired
pinMode(relay7Pin, OUTPUT);
pinMode(relay8Pin, OUTPUT);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
pinMode(lowWaterPin, INPUT_PULLUP);// ATO
pinMode(highWaterPin, INPUT_PULLUP);//ATO
pinMode(pumpPin, OUTPUT);// ATO
Blynk.begin(auth); // Here your Arduino connects to the Blynk Cloud.
timer.setInterval(1000L, take_temp_readings); // Setup a function to be called every second
timer.setInterval(5000L, send_data_to_blynk);
timer.setInterval(1500L, Heater);
timer.setInterval(1300L, Cooler);
timer.setInterval(1000L, setLed);
timer.setInterval(1000L, clockDisplay); // digital time displayed every second
timer.setInterval(60000L, activetoday); // check every minute if schedule should run today
timer.setInterval(60000L, reconnectBlynk); // check every 60s if still connected to server
timer.setInterval(1000L, wavecontrol);
timer.setInterval(1000L, ATOcontrol);
}//--(end setup )---
void loop() /****** LOOP: RUNS CONSTANTLY ******/
// get the current time, for this time around loop
// all millis() timer checks will use this time stamp
unsigned long currentMillis = millis();
unsigned long currentMillis0 = millis();
ledFade0(currentMillis0);
unsigned long currentMillis1 = millis();
ledFade1(currentMillis1);
}//--(end main loop )---
//*********( THE END )***********
any clues on this is it software of it the arduino toast, I’m starting to think arduino is cooked
Only you can determine if the pin is OK by testing with a different sketch.
