3 pieces ESP 8266, 1 piece of oled and 1 piece of application
Hello to everyone.
  1. Esp 8266= measures temperature with ds18b20 and oled installed.
  2. Esp 8266 = relay module connected.
  3. Esp 8266= BME 280 sensor connected. The external environment is measuring.
I see the 1rd (ds18b20) and 3rd(bme280) devices values in the phone application.
But How do I transfer the values from the 3rd device to the 1st oled screen on the 1st device?
Is this possible?`
I want to see all the values on the screen, depending on the 1st case.
http://docs.blynk.cc/#widgets-other-bridge
the application allows only 1 bridge.
3rd device codes:
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK 14
#define BME_MISO 12
#define BME_MOSI 13
#define BME_CS 15
Adafruit_BME280 bme(BME_CS); // hardware SPI
char auth[] = "";
char ssid[] = "msd";
char pass[] = "CFPGawXk";
//BME280 bme; //Create an instance of the sensor
#define SEALEVELPRESSURE_HPA (1013.25)
float temp;
float hum;
float pres;
  timer.setInterval(1000L, sending);
  bme.begin();
void sending()
  temp=bme.readTemperature ();
  hum=bme.readHumidity();
  pres=bme.readPressure() / 100.0F;
   Serial.print(temp);
    Serial.println(hum);
     Serial.println(pres);
  Blynk.virtualWrite(V10, temp);
  Blynk.virtualWrite(V11, hum);
  Blynk.virtualWrite(V12, pres);
connected to oled screen.
I need to add the values on the 3rd device here.
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
U8G2_SSD1306_64X48_ER_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);   // EastRising 0.66" OLED breakout board, Uno: A4=SDA, A5=SCL, 5V powered
#include <OneWire.h>
OneWire oneWire(2);
DallasTemperature DS18B20(&oneWire);
DeviceAddress DS18B20adres;
int offset;
int settemp;
int pozoffset;
int negoffset;
float temp;
float tempson;
WidgetBridge bridge1(V4);
WidgetLED led1(V5);
char auth[] = ".................";
char pass[] = "..................";
BLYNK_WRITE(V9)
 settemp = param.asInt(); // ayarlanan hedef sıcaklığı blynk den alıyoruz
//Blynk.virtualWrite(V8,settemp); // hedef sıcaklığı blynk e yazdırıyoruz.
BLYNK_WRITE(V1)
  offset = param.asInt(); // sıcaklık düzeltme katsayısını app üzerinden alıyoruz
BLYNK_WRITE(V2)
 pozoffset  = param.asInt(); // pozitif konfor offsetini app den alıyoruz
BLYNK_WRITE(V3)
 negoffset = param.asInt(); // negatif konfor offsetini app den alıyoruz.
//""""""""""""""""""6666666
void sending()
//if(DS18B20.getTempC(DS18B20adres)==0)
DS18B20.requestTemperatures();
   temp = DS18B20.getTempC(DS18B20adres);
  Serial.print("orgtemp");
  Serial.print(temp);
  Serial.println("c");
   tempson=temp+(offset*0.1);
  Serial.print("settemp");
Serial.print(settemp);
  Blynk.virtualWrite(V6, tempson);  // sıcaklık değerini app e yazdırıyoruz.
 Serial.print("tempson");
 Serial.print(tempson);
 if(tempson>settemp+(pozoffset*0.1))
  bridge1.digitalWrite(5, LOW);
    led1.off();
 if(tempson<settemp-(negoffset*0.1))
      bridge1.digitalWrite(5, HIGH);
     led1.on();
BLYNK_CONNECTED()
  bridge1.setAuthToken("...............................");
  Blynk.syncAll();
      u8g2.begin();
u8g2.clearBuffer();
DS18B20.begin();
  DS18B20.getAddress(DS18B20adres, 0);
  DS18B20.setResolution(DS18B20adres, 12);
  u8g2.firstPage();
  do {
    draw();
  } while( u8g2.nextPage() );
  u8g2.firstPage();
  do {
    draw2();
void draw(){
    u8g2.clearBuffer();
  u8g2.setFont(u8g2_font_timR18_tf);
  u8g2.setCursor(0, 19);
u8g2.print("SET:");
  u8g2.setCursor(20, 45);
u8g2.println(settemp);
  u8g2.sendBuffer();
void draw2(){
 u8g2.clearBuffer();
u8g2.print("ODA:");
  u8g2.setCursor(5, 45);
u8g2.println(tempson);
  u8g2.sendBuffer();
??? I can and have used multiple bridges in a single sketch (linking to other sketches in other devices)
Also, please edit your posts to properly format the pasted code for viewing…
Blynk - FTFC
I don’t use bridges, but multiple bridges are certainly possible:
BME 280 data bridge condition for printing on the LCD screen.
I will explain it like this.
V10, V11, V12, I need to print the data from the pins, oled screen.
I am already getting this data app.
float oled screen a = v10
float oled screen b = v11
lcdprint (oled screen a) .etc …
Like this.
My apprentice.
Codes are exemplary.
I got an idea.
Can I do it with BlynksyncVirtual.
float temp = Blynk.syncVirtual (V10);
write lcd, oled etc …
Hi Msuphi
I made with 4 device code using your 3rd devie code
Thanx a lot!!!
:wink:
Art
take a look
#include <Wire.h>
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 15
char auth[] = “zzzz”;
char ssid[] = “xxxx”;
char pass[] = “yyyy”;
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
float temp;
float hum;
float pres;
float alt;
bme.begin();
Serial.println(F(“BME280 test”));
    if (!bme.begin(0x76)) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
Serial.println("-- Default Test --");
Serial.println();
void sending()
pres=bme.readPressure()/ 100.0F;
alt=(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.print(temp);
Serial.println(alt);
Blynk.virtualWrite(V13, alt);
