Can you share the code here. Thanks.
So which is it? Switch or momentary button?
The example I had pointed you to, works with a momentary button. Press once led ON, press again led OFF.
char auth[] = "asasas"; //insert here your token generated by Blynk
char ssid[] = "asasa";
char pass[] = "asasa";
//Constants
const int led1 = 12;
const int led2 = 14;
//Variables
int buttonValue; //Stores analog value when button is pressed
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
buttonValue = analogRead(A0); //Read analog value from A0 pin
//For 1st button:
if (buttonValue>=532 && buttonValue<=545){
digitalWrite(led1, HIGH);
//For 2nd button:
else if (buttonValue>=441 && buttonValue<=498){
digitalWrite(led2, HIGH);
else{
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
Serial.println(analogRead(A0));
delay(100);
Yes, I succeeded with the example you showed, when I used Digital Pin, and it didn’t work when I switched to Analog Pin.
—> blynk.iot-cm.com <—
An unsupported cloud-based private server system running an unknown version of the Blynk server software. Exposing all of your data to the website owner, and anyone else he may choose to sell it to.
Good luck with that
sorry I have nothing to do with that, I deleted it.
Why do you need analog pin?
Do you need to identify each button/switch? Does each button/switch need to turn on a specific led? Do they need to function independent of each other (i.e. be able to turn on more then one led at a time)?
I think you need to make clear what you are trying to accomplish, and how it should function first. Otherwise we will not be able to provide accurate help.
Also, you should take some time to understand some of the fundamentals of BLYNK
Also, depending on your level of programming knowledge, you may benefit from watching a few YouTube videos on Arduino programing Basics.
oh sorry wkwkwkwk, this is just a misunderstanding of language, I don’t really understand English well and correctly. thank you I have understood a little what you are talking about. I have modified my code.
I have succeeded, thank you all. : D
@projecttrinof: should you try this one below as I revised it a bit for you. Then if it is the one you want or you could continue to adjust as per your requirement … then go further with Blynk vitual pins. Hope this helps and good luck !
//Constants
//Variables
BlynkTimer timer1;
bool btnAct = false;
void physicalbtnPressed()
if (buttonValue <= 60) btnAct = false;
//For 1st button:
if (buttonValue >= 532 && buttonValue <= 545 && btnAct == false){
btnAct = true;
digitalWrite(led1, !digitalRead(led1));
//For 2nd button:
else if (buttonValue >= 441 && buttonValue <= 498 && btnAct == false){
digitalWrite(led2, !digitalRead(led2));
else {
btnAct = true;
Serial.println(buttonValue);
digitalWrite(led1, LOW); // set defalt value for led1
digitalWrite(led2, LOW); // set defalt value for led2
timer1.setInterval(100L, physicalbtnPressed);
timer1.run();
The above code I suppose you are doing pull down for ADC pin it means its value fluctuates less 80 …but if you want to pull it up then you could revise the variable btnAct as follows:
if (buttonValue > 975) btnAct = false;
replaces this one
Please edit your code and delete the custom server. I have managed to make this with my own code, but I will try it and will be very grateful. and I will tell you the results.
Saya kahabisan PIN jiga akan menggunakan GPIO digital PIN
If this is useful for others, I have successfully used this code
char auth[] = "sempak"; //insert here your token generated by Blynk
char ssid[] = "sempak";
char pass[] = "sempak";
void checkPhysicalButton();
int led1state = LOW;
int led2state = LOW;
int buttonState = 0;
int buttonValue1;
int buttonValue2;
// Every time we connect to the cloud...
BLYNK_CONNECTED() {
Blynk.syncVirtual(V0);
Blynk.syncVirtual(V1);
// Alternatively, you could override server state using:
//Blynk.virtualWrite(V0, led1state);
//Blynk.virtualWrite(V1, led2state);
// When App button is pushed - switch the state
BLYNK_WRITE(V0) {
led1state = param.asInt();
digitalWrite(led1, led1state);
BLYNK_WRITE(V1) {
led2state = param.asInt();
digitalWrite(led2, led2state);
buttonValue1 = analogRead(A0);
buttonValue2 = analogRead(A0);
if (buttonValue1>=532 && buttonValue1<=545) {
if (buttonState != 0) {
// Toggle LED state
led1state = !led1state;
// Update Button Widget
buttonState = LOW;
else if (buttonValue2>=441 && buttonValue2<=498) {
// Toggle LED state
led2state = !led2state;
buttonState = LOW;
buttonState = HIGH;
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
// Setup a function to be called every 100 ms
timer.setInterval(100L, checkPhysicalButton);
timer.setInterval(100L, []() { // Run every 100 milliseconds
Serial.println(analogRead(A0)); // Display the value
This should be replace with a timer instead… delay() of any sort is not a good idea in the main loop
Give you an example? ![]()
Serial.print("buttonValue1 =");
Serial.println(buttonValue1);
Serial.print("buttonValue2 =");
Serial.println(buttonValue2);
Serial.print("analogRead(A0) =");
although I suspect analogRead(A0), buttonValue1 and buttonValue2 will always be the same.
I have lots of timer references here…
Even a compact Lambda option…
// Timed Lambda Function - Run in Void Setup()
}); // END Timer Function
I have just revised the main part for you. The rest job you should work to continue “fine-tuning” it. I have done for this with ADC pin running well for 2 years already. The above is the basic that if you understand its code then you can be revising it mapping with your schematic. There will be much job ahead that only you get it if some further experiment to be done.
Last but not least, you dont just copy the threshold values from the link I tagged in the above post … did you? If you did it is incorrect threshold for your board. Those threshold values should be developed by you and your schematic.
