Here is my code . I have few bug in below.
When timing is in 4 the Zone LED will be Remain High in automode even mode change from Zone4 to Zone1
If timing Set like 10:00:00 to 11:00:00 It wont work. Work when 10:01 to 10:59 or 10:01 to 11:01
In time Input Widget . for testing purpose i selected particular weekday for example
zone1: allweekday
Zone2: all week day
zone3: diselcted on Wednesday i.e today
zone 4: all weekdays
I expected zone1,zone2,zone4 Relay on on respective days .Zone3 must not turn on Relay betwen start time and stop time. IN below code its turing on#include"glob.h" #define BLYNK_PRINT Serial #include <ESP8266WiFi.h> #include <BlynkSimpleEsp8266.h> #include <WidgetRTC.h> BlynkTimer timer; WidgetRTC rtc; // Set RTC widget. char auth[] = "XXXXXXXXXXXXXXX"; char ssid[] = "XXXX"; char pass[] = "XXXX"; WidgetLED led25(25); WidgetLED led22(22); WidgetLED led23(23); WidgetLED led24(24); void setup() { Serial.begin(115200); Blynk.begin(auth, ssid, pass); pinMode(D5, OUTPUT);// Used for Temprature relay pinMode(D7, OUTPUT);// Used for SUN_Sat Relay pinMode(D6, OUTPUT);// Used for Mon_FRI Relay pinMode(D8, OUTPUT);// Used for ALL Day Relay rtc.begin(); setSyncInterval(360); timer.setInterval(10000L, TimeZone1_Function); // Update Time Check every 10 seconds timer.setInterval(10000L, TimeZone2_Function); // Update Time Check every 10 seconds timer.setInterval(10000L, TimeZone3_Function); // Update Time Check every 10 seconds timer.setInterval(10000L, TimeZone4_Function); // Update Time Check every 10 seconds timer.setInterval(1000, Chk_manual_Auto_Status); } void loop() { Blynk.run(); timer.run(); sprintf(Date, "%04d/%02d/%02d", year() , month() , day() ); sprintf(Time, "%02d:%02d:%02d", hour(), minute(), second()); Blynk.virtualWrite(V11, Date); Blynk.virtualWrite(V10, Time); } BLYNK_CONNECTED() { Blynk.syncVirtual(V3); // sync timeinput widget Blynk.syncVirtual(V4); // sync timeinput widget Blynk.syncVirtual(V5); // sync timeinput widget Blynk.syncVirtual(V6); // sync timeinput widget Blynk.syncVirtual(V2); Blynk.syncVirtual(V50); } BLYNK_WRITE(V3)// TimeZone1 TimeInput Store in below variable { TimeInputParam t(param); SThour = t.getStartHour(); STmin = t.getStartMinute(); STsec = t.getStartSecond(); SPhour = t.getStopHour(); SPmin = t.getStopMinute(); SPsec = t.getStopSecond(); } BLYNK_WRITE(V4)// TimeZone2 TimeInput Store in below variable { TimeInputParam t(param); Wk_Emd_SThour = t.getStartHour(); Wk_Emd_STmin = t.getStartMinute(); Wk_Emd_STsec = t.getStartSecond(); Wk_Emd_SPhour = t.getStopHour(); Wk_Emd_SPmin = t.getStopMinute(); Wk_Emd_SPsec = t.getStopSecond(); } BLYNK_WRITE(V5)// TimeZone3 TimeInput Store in below variable { TimeInputParam t(param); Al_SThour = t.getStartHour(); Al_STmin = t.getStartMinute(); Al_STsec = t.getStartSecond(); Al_SPhour = t.getStopHour(); Al_SPmin = t.getStopMinute(); Al_SPsec = t.getStopSecond(); } BLYNK_WRITE(V6)// TimeZone4 TimeInput Store in below variable { TimeInputParam t(param); TimeZ4__SThour = t.getStartHour(); TimeZ4__STmin = t.getStartMinute(); TimeZ4__STsec = t.getStartSecond(); TimeZ4__SPhour = t.getStopHour(); TimeZ4__SPmin = t.getStopMinute(); TimeZ4__SPsec = t.getStopSecond(); } BLYNK_WRITE(V51) // Time Zone1 Button Selected { if (param.asInt() == 1) { Serial.println("Time Zone1 is selected "); TimeZone1 = 1; TimeZone2 = 0; TimeZone3 = 0; TimeZone4 = 0; Blynk.virtualWrite(V52, 0); Blynk.virtualWrite(V53, 0); Blynk.virtualWrite(V54, 0); } else { TimeZone1 = 0; led22.off(); } } BLYNK_WRITE(V52) // Time Zone2 Button Selected { if (param.asInt() == 1) { Serial.println("Time Zone 2 is selected "); TimeZone2 = 1; TimeZone3 = 0; TimeZone1 = 0; TimeZone4 = 0; Blynk.virtualWrite(V51, 0); Blynk.virtualWrite(V53, 0); Blynk.virtualWrite(V54, 0); } else { TimeZone2 = 0; led23.off(); } } BLYNK_WRITE(V53) // Time Zone3 Button Selected { if (param.asInt() == 1) { Serial.println("Time Zone3 selected "); // timer.setTimeout(50, resetTerminal); // timer.setTimeout(50, resetManual); // timer.setTimeout(50, checklastbuttonpressed); TimeZone3 = 1; TimeZone1 = 0; TimeZone2 = 0; TimeZone4 = 0; Blynk.virtualWrite(V51, 0); Blynk.virtualWrite(V52, 0); Blynk.virtualWrite(V54, 0); } else { TimeZone3 = 0; led24.off(); } } BLYNK_WRITE(V54) // Time Zone4 Button Selected { if (param.asInt() == 1) { Serial.println("Time Zone4 selected "); TimeZone4 = 1; TimeZone1 = 0; TimeZone2 = 0; TimeZone3 = 0; Blynk.virtualWrite(V51, 0); Blynk.virtualWrite(V52, 0); Blynk.virtualWrite(V53, 0); } else { TimeZone4 = 0; led25.off(); } }
void TimeZone1_Function()
{if (TimeZone1 == 1)
// call with timer every 30 seconds or so
// Get RTC time
sprintf(currentTime, “%02d:%02d:%02d”, hour(), minute(), second());
Serial.print("Current Time: ");
Serial.println(currentTime);// Get Time Input Widget time sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec); Serial.print("Start Time: "); Serial.println(startTime); sprintf(stopTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec); Serial.print("Stop Time: "); Serial.println(stopTime); if (hour() >= SThour && hour() <= SPhour) { if (minute() >= STmin && minute() <= SPmin) { Serial.println("RELAY IS ON"); Serial.println(".........................."); digitalWrite(D5, HIGH); // Turn ON built-in LED led22.on(); } else { Serial.println("RELAY IS OFF"); Serial.println(".........................."); digitalWrite(D5, LOW); // Turn ON built-in LED led22.off(); } } else { led22.off(); } } } void TimeZone2_Function() { if (TimeZone2 == 1) { sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second()); Serial.print("Current Time: "); Serial.println(currentTime); // Get Time Input Widget time sprintf(Sat_Sun_startTime, "%02d:%02d:%02d", Wk_Emd_SThour, Wk_Emd_STmin, Wk_Emd_STsec); Serial.print("Start Time: "); Serial.println(Sat_Sun_startTime); sprintf(Sat_Sun_stopTime, "%02d:%02d:%02d", Wk_Emd_SPhour, Wk_Emd_SPmin, Wk_Emd_SPsec); Serial.print("Stop Time: "); Serial.println(Sat_Sun_stopTime); if (hour() == Wk_Emd_SThour && hour() == Wk_Emd_SPhour) { if (minute() >= Wk_Emd_STmin && minute() <= Wk_Emd_SPmin) { Serial.println("RELAY IS ON"); Serial.println(".........................."); digitalWrite(D7, HIGH); // Turn ON built-in LED led23.on(); } else { Serial.println("RELAY IS OFF"); Serial.println(".........................."); digitalWrite(D7, LOW); // Turn ON built-in LED led23.off(); } } else { led23.off(); } } } void TimeZone3_Function() {
if (TimeZone3 == 1)
{// call with timer every 30 seconds or so // Get RTC time sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second()); Serial.print("Current Time: "); Serial.println(currentTime); // Get Time Input Widget time sprintf(AllDay_startTime, "%02d:%02d:%02d", Al_SThour, Al_STmin, Al_STsec); Serial.print("Start Time: "); Serial.println(AllDay_startTime); sprintf(AllDay_stopTime, "%02d:%02d:%02d", Al_SPhour, Al_SPmin, Al_SPsec); Serial.print("Stop Time: "); Serial.println(AllDay_stopTime); if (hour() >= Al_SThour && hour() <= Al_SPhour) { if (minute() >= Al_STmin && minute() <= Al_SPmin) { Serial.println("RELAY IS ON"); Serial.println(".........................."); digitalWrite(D6, HIGH); // Turn ON built-in LED led24.on(); } else { Serial.println("RELAY IS OFF"); Serial.println(".........................."); digitalWrite(D6, LOW); // Turn ON built-in LED led24.off(); > }
} } else { led24.off(); } } void TimeZone4_Function() { if (TimeZone4 == 1) {
// Get RTC time
sprintf(TimeZone4SRTTime, "%02d:%02d:%02d", TimeZ4__SThour, TimeZ4__STmin, TimeZ4__STsec);
Serial.println(TimeZone4SRTTime);
sprintf(TimeZone4STPTime, "%02d:%02d:%02d", TimeZ4__SPhour, TimeZ4__SPmin, TimeZ4__SPsec);
Serial.println(TimeZone4STPTime);
if (hour() >= TimeZ4__SThour && hour() <= TimeZ4__SPhour)
if (minute() >= TimeZ4__STmin && minute() <= TimeZ4__SPmin)
digitalWrite(D8, HIGH); // Turn ON built-in LED
led25.on();
} else
digitalWrite(D8, LOW); // Turn ON built-in LED
led25.off();
} else
led25.off();
/* void checklastbuttonpressed ()
if ((TimeZone1 == 1) && (TimeZone2 == 0)) {
oldstatus = 1;
if ((TimeZone1 == 0) && (TimeZone2 == 1)) {
oldstatus = 2;
if ((TimeZone1 == 1) && (TimeZone2 == 1)) {
oldstatus = 3;
if (TimeZone3 == 1) {
oldstatus = 4;
// if(uptoyou==1){ oldstatus=5; }
if ((TimeZone1 == 0) && (TimeZone2 == 0) && (TimeZone3 == 0)) {
oldstatus = 5;
void restorelastbuttonpressed ()
if (oldstatus == 1) {
TimeZone1 = 1;
Blynk.virtualWrite(V51, 1);
if (oldstatus == 2) {
TimeZone2 = 1 ;
Blynk.virtualWrite(V52, 1);
if (oldstatus == 3)
TimeZone2 = 1;
TimeZone1 = 1;
if (oldstatus == 4) {
TimeZone3 = 1;
Blynk.virtualWrite(V53, 1);
if (oldstatus == 5)
TimeZone1 = 0;
TimeZone2 = 0;
TimeZone3 = 0;
//uptoyou = 0;
BLYNK_WRITE(V50) // Manual/Auto selection
if (param.asInt() == 0)
manual = 1;
Serial.println("Manual mode is selected ");
// restorelastbuttonpressed ();
} else
manual = 0;
Serial.println("AUTO mode is selected ");
AutoMode_Function();
//checklastbuttonpressed();
void Chk_manual_Auto_Status()
if (manual == 0)
void AutoMode_Function()
TimeZone1 = 1;
if (hour() >= Wk_Emd_SThour && hour() <= Wk_Emd_SPhour)
TimeZone2 = 1;
TimeZone3 = 1;
TimeZone4 = 1;
Blynk.virtualWrite(V54, 1);
} else if (TimeZone1 == 0 && TimeZone2 == 0 && TimeZone3 == 0 && TimeZone4 == 0)
