There is something that glitched in the Level Widget since last App update. I had posted about it myself, but it might have gotten lost in the shuffle. (SOLVED) Small visual glitch in Level Bar on HD display Have you used any negative values in your project? That is where I noticed the discrepancies in mine the most.
I’ m sorry but I didn’t found any post about this problem and then I open a new topic. I think problem is the same as reported by you.
At this moment I have not checked behavior for negative values, later when I go back home I will check behavior with negative values and I’ll update this post.
No problems at all with your post I think it helps show the developers more detail and the variant ways of determining the fault. Also makes it easier to differentiate between a real issue and a user error.
