I am having trouble with my local blynk server. I can’t get my ESP8266 to connect. I am using the blynk demo and can connect to the blynk server, but not to my raspberry pi server. I can see that the ESP8266 is connecting to the wi-fi, but it never shows as connected when I watch from the server administration browser and it shows as disconnected on the app. I can see the app has connected to the server, and have checked the authentication token several times to ensure it is correct. I believe the error is somewhere in my server setup, but I am not sure where to start looking. I have been through the log, but have not seen anything. Unfortunately I am having trouble getting the log off the raspberry pi. Code I’m uploading via Arduino is below. Pretty sure it doesn’t matter but the ESP8266 is the Adafruit version.
http://twitter.com/blynk_app
You’ll need:
- Blynk App (download from AppStore or Google Play)
- ESP8266 board
example.
char auth[] = "65796dd4eb374.......84d74f433f89";
char ssid[] = "wifi";
char pass[] = "password";
//Blynk.begin(auth, ssid, pass);
Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,191), 8442);
// to avoid delay() function!
