Hi. I have RobotDyn WIFI D1 R2. I have Error with connect to server. First Connection work, but only first. Next are Login Timeout Error. This is my Code
char auth[] = "MYTOKEN"; //insert here your token generated by Blynk
float temp;
int tempPin = 17; // ADC pin
Blynk.begin(auth, "MY SSID", "MYPASS"); //insert here your SSID and password
timer.setInterval(5000L, sendUptime);
void sendUptime()
Blynk.virtualWrite(10, temp); // virtual pin 10
// delay(1000);
temp = analogRead(tempPin);
temp = temp * 0.09765625; // costance (1/1024*100)
