Good morning.
I’m new to Blynk and I do not speak any English.
I am working on the implementation of a safety system measuring the concentration of two gases, methane (CH4) and carbon monoxide (CO) and I need to send a one time message to an email, if the concentration remains within a range Established or if the concentration increases exceeding the next limit in the ranges. It would be exceptional, that no message will be sent if the concentration starts to decrease but for now only the message will be sent if it stays in those ranges or exceeds the following range, I clarify, only once.
I include the code in which I process the reading of the sensors and the code for the sending of said message, being CH4 and CO, the concentrations of methane and carbon monoxide respectively.
int MQ4 = 34; int MQ9 = 35;
void setup(){
pinMode(MQ4, INPUT); pinMode(MQ9, INPUT);
void loop(){
concentracion();
void concentracion(){
int ADC_MQ4 = analogRead(MQ4); // Leemos la salida analógica del MQ4
float Vout_MQ4 = ADC_MQ4 * (3.3 / 4096.0); // Convertimos la lectura en un valor de voltaje
float Rs_MQ4 = ((5.0 - Vout_MQ4) / Vout_MQ4); // Calculamos Rs
float Rs_Ro_MQ4 = Rs_MQ4; // / Ro_MQ4; // Calculamos Rs/Ro
float CH4 = 1103.1*(pow(Rs_Ro_MQ4, -2.71)); // Calculamos la concentración de metano con la ecuación obtenida
Serial.print(" Concentracion de CH4: ");
Serial.print(CH4, 3);
Serial.print(" ppm");
int ADC_MQ9 = analogRead(MQ9); // Leemos la salida analógica del MQ9
float Vout_MQ9 = ADC_MQ9 * (3.3 / 4096.0); // Convertimos la lectura en un valor de voltaje
float Rs_MQ9 = ((5.0 - Vout_MQ9) / Vout_MQ9); // Calculamos Rs
float Rs_Ro_MQ9 = Rs_MQ9; // / Ro_MQ9; // Calculamos Rs/Ro
float CO = 605.62*(pow(Rs_Ro_MQ9, -2.056)); // Calculamos la concentración de monoxido de carbono con la ecuación obtenida
Serial.print(" Concentracion de CO: ");
Serial.print(CO, 3);
Serial.println(" ppm");
Blynk.virtualWrite(V1, CH4);
Blynk.virtualWrite(V2, CO);
void mensaje(){
////////////////// Mensajes para monoxido de carbono /////////////////
if ((CO < 50) || (CH4 < 30)) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases es normal.");
if ((CO >= 50) || (CH4 >= 30)) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases a aumentado.");
if (CO >= 80 || CH4 >= 100) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases supero niveles seguros.");
if (CO >= 1200 || CH4 >= 500) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases supero niveles criticos.");
if (CO >= 1500 || CH4 >= 800) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases supero niveles peligrosos.");
if (CO >= 4000 || CH4 >= 1000) {
Blynk.email("raytejada07@gmail.com", "Concentracion de gases", "La concentracion de gases supero niveles altamente peligrosos.");
I hope you can help me and thanks in advance.
