Hi - I’ve noticed the RTC widget allows you to select GMT+11 for example for Australia / Sydney, however + 11 is assuming daylight savings time - BUT its not daylight savings in Australia, it should be GMT+10 at the moment. Therefore the clock is ONE hour fast when displaying on Blynk.
Anyway I can easier configure this to disable daylight savings on RTC setting as it would be nice if it simply synced with local time on the server that the Blync Server is running on.
yes I do use a local server. You can see from screenshot below that the time at the top of the phone 18:27 (correct time), time in LCD widget as 19:26 (+1 hr), and the time in the HISTORY WIDGET as 18:27 - something weird seems to be happening ?
@Dmitriy when did “locations” become available in RTC as I just get +1 +2 +3 etc, no reference to Australia or anywhere else. Maybe it is an Android setting?
@Dmitriy Hi - i’ve noticed an update available today on iOS store and I’ve updated accordingly.
But the problem is now worse See picture attached. NOTE: I have selected GMT+11 Australia/Sydney (for some reason GMT+10 not their which is the real offset at this current period of the year).
Note: I am using local server with server-0.18.0-SNAPSHOT.jar
