I am working on a automation that will allow me to control the dial on my propane heater at my cabin remotely. I would also like to be able to measure the temperature inside and outside the cabin and manage remotely with Blynk. For this project I have a
NodeMCU with WiFi
DS18B20 temperature sensors
MG995 Servo Motor
I have been successfully able to run a program which allows activation of the servo and I have been able to run a program that reads the data from a single thermometer. I have attempted to combine the sketches, however when uploaded to the board I am unable to read temperature or control the servo via Blynk. I am relatively new to coding, and I imagine I am making an error somewhere.
Temperature Code - Single sensor
#include <Blynk.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 2
char auth[] = "my auth";
char ssid[] = "my wifi";
char pass[] = "my password";
int roomTemperature; // Room temperature in F
// Wait until connected
sensors.begin();
sensors.setResolution(10);
timer.setInterval(2000L, sendTemps);
// Notice how there is very little in the loop()? Blynk works best that way.
// Notice how there are no delays in the function below? Blynk works best that way.
void sendTemps()
roomTemperature = sensors.getTempFByIndex(0);
Blynk.virtualWrite(1, roomTemperature);
#include <Blynk.h>
#include <Servo.h>
#define ONE_WIRE_BUS 2 //D4
Servo servo;
BLYNK_WRITE(V3) {
servo.write(param.asInt());
while (Blynk.connect() == false)
servo.attach(15); {
sensors.begin();
void sendTemps()
roomTemperature = sensors.getTempFByIndex(0); getTempCByIndex(0) for celcius.
Again my goal is to control the servo along with two temperature probes remotely. So far I have been able to get the servo to run with an individual program, and one temperature probe to work, my attempts have been unable to make two temperature probes read.
Any help or guidance in combing the two codes along with adding an additional temperature sensor would be greatly appreciated!
Thanks!
Scott
The DS18B20:s EEPROM is specified to handle +50.000 rewrites (it stores the data before sending) without failure, but reading the sensors once every 2 seconds equals 43.200 readings a day! So I recommend that you ease up on frequency as a precaution.
@skrankk in order to find each sensorās unique ID, I have used this program, marked each address into a document, then marked each sensor with an identifying mark corresponding to the address in said document.
// This sketch looks for 1-wire devices and
// prints their addresses (serial number) to
// the UART, in a format that is useful in Arduino sketches
// Tutorial:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
OneWire ds(3); // Connect your 1-wire device to pin 3 (Arduino pin numbering)
void setup(void) {
discoverOneWireDevices();
void discoverOneWireDevices(void) {
byte i;
byte present = 0;
byte data[12];
byte addr[8];
Serial.print("Looking for 1-Wire devices...\n\r");
while(ds.search(addr)) {
Serial.print("\n\rFound \'1-Wire\' device with address:\n\r");
for( i = 0; i < 8; i++) {
Serial.print("0x");
if (addr[i] < 16) {
Serial.print('0');
Serial.print(addr[i], HEX);
if (i < 7) {
Serial.print(", ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
Serial.print("\n\r\n\rThat's it.\r\n");
ds.reset_search();
return;
void loop(void) {
// nothing to see here
Hello again, I finally got my part from china and now Iāve completely forgotten where I was, as usual.
Gunner, The device finder code you have here, does it run on the node mcu esp8266?
That is all I have here.
I did upload it and went to serial monitor but didnāt see anything except some squares=backwards ? and3. Iām sorry I tried to but it wont copy/paste.
I did change the pin to 2 b/c thatās where I had the sensor plugged in D4 physical.
UPDATE
I changed your code back to the original pin3 and looked up which was gpio3 and that is the RX pin so I connected my sensor to that and tried to upload again and got stopped by
ERROR espcom-upload-mem-failed.
So I backed out, disconnected the gpio3 and loaded a good sketch and it uploaded fine. At least I didnāt ruin the board!
Am I completely off the beam again?
So what do you think happened on my first try?
Are we sure this code is meant for this board or is it for something else?
It should run on anything that runs Arduino code (C++ variant)ā¦ Arduino, ESP8266 based, ESP32ā¦ but you will need to tweek for actual pins used, etcā¦
I tried and the only result was as i said a bunch of squares followed by an equal sign and then backwards question marks with a 3 in the middle. I did change the pin b/c pin3 is RX on the board.
Thanks Greatly, that fixed it. Up until today I have never touched the baud rate in three projects. Of course up until today Iād never used the monitor.
Lear something every day. Known as Funstration.
To be continued, Iāve had enough fun for today.
