Hello Blynk team. It all happened in a span of 10 days, everything was running smoothly, all my Blynk projects would run normally, but one fine day every thing stopped. My Blynk app suddenly vanished and I had to reinstall it to get going. But my hard luck, may be because of that update it stopped working ( Blynk v2.20.3). Currently I am working with Blynk library version 0.5.2 on my windows 10 laptop and Android 6.0.1. I have two WiFi networks, one broadband at home and another in my college, was able to connect to both of these networks earlier. I am using ESP32 Dev Module to send DHT22 Temperature and Humidity values to Blynk-cloud.
This is the code:
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
char auth [] = "437d914f907946609c4b970929013bea";
//char ssid [] = "ECMESH";
//char pass [] = "IDontKnowNow";
char ssid [] = "Tenda_285298";
char pass [] = "avniatharv@2017";
#define DHTPIN 2 // What digital pin we're connected to
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
Serial.print ("The current Humidity is =");
Serial.print (h);
Serial.println (" %");
Serial.print ("The current Temperature is =");
Serial.print (t);
Serial.println ("degrees C" );
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite (V5, h);
Blynk.virtualWrite (V6, t);
Blynk.begin (auth, ssid, pass);
//Blynk.begin (auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin (auth, ssid, pass, IPAddress(192,168,1,100), 8442);
dht.begin();
I get this message in serial print:
[7082] Connected to WiFi
[7082] IP: 192.168.0.100
[7082]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.5.2 on ESP32
[7150] Connecting to blynk-cloud.com:80
[9204] Login timeout
[12204] Connecting to blynk-cloud.com:80
[17218] Connecting to blynk-cloud.com:80
[22227] Connecting to blynk-cloud.com:80
[24234] Login timeout
[27234] Connecting to blynk-cloud.com:80
[29241] Login timeout
[32241] Connecting to blynk-cloud.com:80
[34247] Login timeout
[37247] Connecting to blynk-cloud.com:80
[39253] Login timeout
[42253] Connecting to blynk-cloud.com:80
[47259] Connecting to blynk-cloud.com:80
[52266] Connecting to blynk-cloud.com:80
[54272] Login timeout
[57272] Connecting to blynk-cloud.com:80
[59278] Login timeout
[62278] Connecting to blynk-cloud.com:80
I am unable to find the reason why I am not able to connect to Blynk.
I tried with Blynk libraries with other versions (0.5.0&0.5.1) but it didn’t help.
Any help would be appreciated. Thank you
