Sir i am use a nodemcu to control relay with blynk and it works but i need to configure blynk and zapier together where use a command to on the relay but zapier is showing me one or the another error pls can anyone reply
Nobody uses zapier? pls i need a solution to this pls
Always better to use GET rather than PUT in my experience, along with the correct GET syntax.
It’s also best to test the command by pasting it into the address bar of your browser before moving on to using it in Zapier/IFTTT
WHAT is the Correct Get syntax
sir but i need a tutorial
Everything you need to know about the Blynk side of reading and writing to virtual pins using Zapier is contained in this topic:
and the API documentation that I’ve already linked to.
As far as the Google Assistant side of things is concerned, that’s really outside of the scope of this forum.
