Blynkers.
My target ESP32 platforms of choice are Adafruit’s ESP32V2, with its high quality and Neopixel LED on the board, and Seeed Studio’s XIAO ESP32C6: tiny footprint, great with batteries.
This is not an advertisement, not a promotion, but an opportunity for me to return value to the Blynk community with an extremely useful product and my supporting code.
Seeed Studio’s XIAO 6-Channel Wi-Fi 5V DC Relay combines the XIAO ESP32C6 with 6 relays, indicator lights, and easy Blynk programmability in a surprisingly affordable package. I’ve built one project already with this product.
The six relays are heavy-duty, all completely isolated from each other and from the ESP32. The relays work with AC and DC and are rated to 15A at 120VAC. I am replacing a bunch of Shelly 1 switches with this, and may replace some Sonoffs, too. All in a nice compact package.
Here’s my almost-bare-bones Blynk code to demonstrate this device. Compiling to ESP32C6 and using default partitions, this sketch needs only your Blynk and WiFi credentials (in the two #include files) to demo this device.
There’s a screenshot at the end of my simple demo Blynk app. It’s just a demo.
I hope this is useful to someone in the Community.
Code: sketch with two #include files – one for WiFi credentials, the other for Blynk credentials. I have posted this on Github, will post more robust code soon.
All thoughts welcome.
Main sketch. (#include files to follow.)
// XIAO 6-Channel Relay Demo Sketch
// Seeed Studio https://www.seeedstudio.com/6-Channel-Wi-Fi-5V-DC-Relay-p-6373.html
// Seeed Studio https://www.seeedstudio.com/Seeed-Studio-XIAO-ESP32C6-p-5884.html
// Board: XIAO_ESP32C6
// PARTITION SCHEME: DEFAULT 4MB with spiffs
#define SERIAL_SPEED 230400 // My usual speed for Serial/development work
//#define SERIAL_SPEED 115200
#define BLYNK_FIRMWARE_VERSION "1.0.1" //
#define PROGRAM_NAME_VERSION "1-0-1" // Dashes, not Dots
#define SKETCH_NAME "XIAO_Relay_v" PROGRAM_NAME_VERSION // used in WiFi setup, Blynk and OTA
#define DEVICE_NAME "XIAO-Relay-v" PROGRAM_NAME_VERSION // used in WiFi setup, Blynk and OTA
// ****************** XIAO 6-Channel Relay *****************
#include "MY_BLYNK_CREDENTIALS_DEMO.h"
#define BLYNK_TEMPLATE_ID MY_XIAO_RELAY_TEMPLATE_ID // FROM MY_BLYNK_CREDENTIALS.h
#define BLYNK_TEMPLATE_NAME MY_XIAO_RELAY_TEMPLATE_NAME // FROM MY_BLYNK_CREDENTIALS.h
#define MY_BLYNK_AUTHCODE MY_XIAO_RELAY_DEVICE_AUTHCODE // FROM MY_BLYNK_CREDENTIALS.h
// Added April 2026
#include "MY_WIFI_CREDENTIALS_DEMO.h" // #defines MY_WIFI_SSID AND MY_WIFI_PASSWORD
#include "MY_BLYNK_COLORS.h"
// WiFi Stuff
#include "WiFi.h" // Now included from Espressif ESP32 3.0.0 Board package
#include <WiFiMulti.h>
WiFiMulti wifiMulti; // set up the WiFi object
const uint32_t connectTimeoutMs = 5000; // timing for WiFiMulti testing connection
// Blynk Stuff
#include <BlynkSimpleEsp32.h>
// Blynk Timers
// This sketch uses timers to kick off key processes
// See Pete Knight's doc at https://community.blynk.cc/t/using-blynktimer-or-simpletimer/53326
// Set up my standard timer here, before we bring in the Heartbeat
BlynkTimer myTimer;
/* 1 - Heartbeat (heartbeatBlink) - Interval Timer - simple pulse to show we're alive. May be switched off.
* Timer call turns heartbeat ON and prints diagnostics.
* It uses a second Duration timer to turn the heartbeat back OFF
* 2 - Do something with the Switches every three seconds
// ** timers get randomized in the code **
// Timer 1: Heartbeat LED and optional Blynk LED on and off
#define HEARTBEAT_INTERVAL 4250 // interval between heartbeats for Blynk Virtual LED in millisec
int heartbeatTimerID; // HEARTBEAT_INTERVAL WILL BE RANDOMIZED +-500 ms (once at startup)
#define HEARTBEAT_DURATION 1250 // duration of each blink in millisec
int heartbeatDurationTimerID; // (set as an interval timer once heartbeat is ON ... to turn it back OFF)
// Timer 2: Do something with the Switches every three seconds
#define TOGGLE_GPIO_INTERVAL 3 * 1000 // Do something every 3 seconds
int toggleGPIOtimerID;
// End of Timers //
// Key Program Global Variables
// Sets up HEARTBEAT widget, heartbeatBlink
#define HEARTBEAT_VPIN V0 // My standasrd Heartbeat VPIN
#define HEARTBEAT_LABEL "Working"
#define HEARTBEAT_COLOR BLYNK_LT_BLUE
bool heartbeatLEDon = false; // this lets me use the same routine for the turn-on timer and the turn-off interval
// Sets up the 6 Switch Widgets
#define SWITCH_WIDGET_COLOR BLYNK_BLACK
#define SWITCH_WIDGET_ON_COLOR BLYNK_GREEN
#define SWITCH_WIDGET_OFF_COLOR BLYNK_GREY
//// XIAO 6-CHannel Relay
// https://wiki.seeedstudio.com/6_channel_wifi_relay/
// https://www.seeedstudio.com/6-Channel-Wi-Fi-5V-DC-Relay-p-6373.html?srsltid=AfmBOoqth5qb8CrGU001aOXWS33ozvj0V8Ax3FVixJnjHNz0Us07LpExMR0
// || Switch 1 GPIO2 GPIO18 Switch 6 /\
// || Switch 2 GPIO21 GPIO19 Switch 5 ||
// \/ Switch 3 GPIO1 GPIO00 Switch 4 ||
const int switchGPIO[6] = { 02, 21, 01, 00, 19, 18 }; // GPIOs on the ESP32C6
const int switchVPIN[6] = { 31, 32, 33, 34, 35, 36 }; // Blynk VPINs for the 6 Switch ON/OFF Widgets
bool currentSwitchState[6] = { false }; // All OFF initially
// SETUP WIFI, BLYNK, HEARTBEAT, AND 6 SWITCHES
// Turn ON all Switches
initializeAllSwitchGPIOs(); // Initialize to OFF
allSwitchesONorOFF ( HIGH ); // Turn all 6 ON (before we try to connect to Serial)
// Use a timer here for any OTA device, particularly the XIAO ESP32
// CONTAINS DELAYS !!
#define SERIAL_PRINT_DELAY 2500 // I use this delay for all ESP32s
time_t serialWaitStartTime = millis(); // Protect against ESP32 hangup of no Serial Monitor available
time_t serialWaitTime = 0;
Serial.begin ( SERIAL_SPEED );
while ( ( ! Serial ) && ( serialWaitTime < SERIAL_PRINT_DELAY ) )
{ /* wait for serial port to connect. Needed for native USB */
serialWaitTime = millis() - serialWaitStartTime;
delay ( SERIAL_PRINT_DELAY - serialWaitTime );
// Turn OFF all Switches
allSwitchesONorOFF ( LOW );
Serial.println ( "\n\n**********************************************" );
Serial.println ( "Firing up " + String ( SKETCH_NAME ) );
Serial.println();
// Connect to WiFi and Blynk
connectToWiFiAndBlynk(); // Connect to WiFi, then to Blynk server
// calls initialzeBlynkWidgets from BLYNK_CONNECTED
// Set Blynk Virtual Heartbeat LED OFF
heartbeatBlink(); // start first heartbeat
Blynk.virtualWrite ( HEARTBEAT_VPIN, 000 );
// Blynk timers control heartbeat, status checking for ON/OFF vs schedule, etc.
setupBlynkTimers(); // Establish Blynk timers after Blynk is connected
Serial.println ( "\n**********************" );
Serial.println ( "... Setup complete ..." );
Serial.println ( "**********************\n" );
} // end setup
void loop() // Standard void loop (no OTA for simplicity)
myTimer.run();
} // end loop
// SET UP BLYNK TIMERS FOR EVERYTHING
void setupBlynkTimers()
Serial.println ( "\nSetting up Blynk timers" );
// Introduce a little randomness to all times so they don't all sync up
long randomizedInterval;
randomizedInterval = HEARTBEAT_INTERVAL + random ( -500, +500 ); // plus of minus half a second
Serial.print ( "... heartbeat interval = " ); Serial.println ( randomizedInterval );
heartbeatTimerID = myTimer.setInterval ( randomizedInterval, heartbeatBlink );
Serial.print ( "... toggleGPIOtimerID = " ); Serial.println ( TOGGLE_GPIO_INTERVAL );
toggleGPIOtimerID = myTimer.setInterval ( TOGGLE_GPIO_INTERVAL, randomlyChangeSwitchStates );
Serial.println ( "... Blynk timers all set up.\n" );
} // end setupBlynkTimers
// BLYNK_CONNECTED GETS CALLED WHEN CONNECTING TO BLYNK SERVERS
// GETS CALLED IMMEDIATELY ON FIRST CONNECT TO BLYNK SERVER, TOO
BLYNK_CONNECTED()
Serial.println ();
Serial.println ( "*************************************************" );
Serial.println ( "BLYNK_CONNECTED..." );
Serial.println ( "*************************************************\n" );
// Set up the Blynk App with all the static info (colors and labels)
// Set up all the Blynk widgets
initializeBlynkWidgets();
} // end BLYNK_CONNECTED
// Set up all Blynk widgets in the app includinng Heartbeat and Reboot
void initializeBlynkWidgets()
Serial.println ( "Initializing all Blynk widgets" );
// Set up heartbeat label and color
Blynk.setProperty ( HEARTBEAT_VPIN, "label", HEARTBEAT_LABEL );
Blynk.setProperty ( HEARTBEAT_VPIN, "color", HEARTBEAT_COLOR );
// Set up the 6 Channel Switch Widgets
for ( int switchIndex = 0; switchIndex < 6; switchIndex++ ) // Switches numbered 1-6; Index goes from 0-5
Blynk.setProperty ( switchVPIN[switchIndex], "label", "Switch " + String ( switchIndex + 1 ) );
Blynk.setProperty ( switchVPIN[switchIndex], "color", SWITCH_WIDGET_COLOR );
Blynk.setProperty ( switchVPIN[switchIndex], "offColor", SWITCH_WIDGET_OFF_COLOR );
Blynk.setProperty ( switchVPIN[switchIndex], "onColor", SWITCH_WIDGET_ON_COLOR );
} // end initializeBlynkWidgets
void initializeAllSwitchGPIOs() // Initialize all 6 GPIO relay controls to OUTPUT and turn OFF
Serial.println( "Initializing All GPIOs to OFF" );
pinMode ( switchGPIO[switchIndex], OUTPUT );
setSwitchState ( switchIndex, LOW );
Serial.println ( "Initialized Switch " + String ( switchIndex + 1 ) + " at GPIO " + String ( switchGPIO[switchIndex]) + " and VPIN " + String ( switchVPIN[switchIndex] ) );
Serial.println();
} // end initializeAllSwitchGPIOs
void allSwitchesONorOFF ( bool newState ) // Turn all 6 switches ON or OFF
setSwitchState ( switchIndex, newState );
Serial.println ( "Changed Switch " + String ( switchIndex + 1 ) + " at GPIO " + String ( switchGPIO[switchIndex]) + " and VPIN " + String ( switchVPIN[switchIndex] ) + " to " + String ( newState) );
Serial.println();
} // end allSwitchesONorOFF
BLYNK_WRITE_DEFAULT() // Using BLYNK_WRITE_DEFAULT to more easily handle 6 different switch inputs with same code
// Also allows keeping the VPINs in an array
// THE VIRTUAL PIN THAT SENT THE MESSAGE TO BLYNK
int writeVpin = request.pin;
String message = "BLYNK_WRITE_DEFAULT called from VPin " + String ( writeVpin );
Serial.println ( "\n\n" + message );
// See which switch - if any - just got changed
if ( writeVpin == switchVPIN[switchIndex] ) // Check which widget got hit
bool newSwitchState = param[0].asInt();
Serial.println ( "User Hit Switch " + String ( switchIndex + 1 ) + ": " + String ( newSwitchState ) );
if ( newSwitchState != currentSwitchState[switchIndex] ) // Change Switch State only if needed
setSwitchState ( switchIndex, newSwitchState );
// Do nothing
return;
} // end BLYNK_WRITE_DEFAULT
void randomlyChangeSwitchStates() // Randomly change switch states
Serial.println ( "\nRandomly changing two Switches" );
int randomSwitch = random ( 0, 6 );
setSwitchState ( randomSwitch, LOW );
setSwitchState ( randomSwitch, HIGH );
reportSwitchStates();
} // end randomlyChangeSwitchStates
void reportSwitchStates() // Read the 6 Switches and print out their GPIO states
Serial.println();
int switchState = digitalRead ( switchGPIO[switchIndex] );
Serial.println ( "Reading Switch " + String ( switchIndex + 1 ) + ": " + String ( switchState ) );
} // end reportSwitchStates
void setSwitchState ( int switchIndex, bool newSwitchState ) // Set a Switch to a value
digitalWrite ( switchGPIO[switchIndex], newSwitchState );
Blynk.virtualWrite ( switchVPIN[switchIndex], newSwitchState );
currentSwitchState[switchIndex] = newSwitchState;
} // end setSwitchState
// OPTIONAL Cutting down on the brightness of the Blynk LED Widget
#define BLYNK_LED_WIDGET_MAX_BRIGHTNESS 150 // Led Widget is [0-255] 150 = not very bright (from 255)
void heartbeatBlink() // Standard code (I usually put in an #include'd file)
if ( heartbeatLEDon ) // LED is ON. Turn it OFF
Blynk.virtualWrite ( HEARTBEAT_VPIN, 000 ); // Blynk LED off
Serial.println ( " ..." );
else // LED is OFF. Turn it ON
// Turn LED_BUILTIN ON (via PWM) and Turn Blynk LED Widget ON
Blynk.virtualWrite ( HEARTBEAT_VPIN, BLYNK_LED_WIDGET_MAX_BRIGHTNESS ); // BLynk LED on
Serial.print ( "\n... heartbeat <" + String ( SKETCH_NAME ) + ">" );
int wifiStatus = WiFi.status();
if ( wifiStatus == WL_CONNECTED )
Serial.print ( " connected as " ); Serial.print ( WiFi.localIP() );
Serial.print ( " to " + String ( WiFi.SSID() ) +
" at " + String ( WiFi.RSSI() ) + "dBm" );
else // not connected to WiFi
Serial.print ( " WiFi.status()=" );
if ( wifiStatus <= 7 && wifiStatus >= 0 ) { Serial.print ( myWiFiStatus[wifiStatus] ); }
else { Serial.print ( wifiStatus ); };
// Set a timer to turn off the heartbeat LEDs in a bit
heartbeatDurationTimerID = myTimer.setTimeout ( HEARTBEAT_DURATION, heartbeatBlink );
heartbeatLEDon = ! heartbeatLEDon; // flip heartberat ON/OFF status
} // end heartbeatBlink
void connectToWiFiAndBlynk() // My standard (simplified) WiFi connection code - usually in an #include file
Serial.println();
Serial.println ( "connectToWiFiAndBlynk called ..." );
// Try to connect to WiFi, REBOOTS UNTIL IT WORKS.
connectToWiFi();
// Sets wifiOnline = true... or it reboots after 5-10 minutes
Serial.println ( "Next, connect to Blynk. \n" );
Blynk.config ( MY_BLYNK_AUTHCODE );
Blynk.connect() ;
// If Blynk is not connected, start the Blynk connect cycle
if ( ! Blynk.connected() )
// Blynk is NOT online
Serial.println();
Serial.println ( "connectToWiFiAndBlynk INITIALLY CANNOT connect to Blynk" );
Serial.println();
ESP.restart();
} // Blynk is offline
Serial.println ( "... Blynk connected up nicely\n" );
} // end connectToWiFiAndBlynk
// Global variable indicating WiFi Online
#define WIFI_INITIAL_CONNECT_DURATION 1500 // Wait 1.5 seconds between WiFi.begin and first test for connectivity
#define WIFI_RETRY_CONNECT_INTERVAL 10L * 1000L // 10 seconds between WiFi connect retries
#define WIFI_RETRIES_BEFORE_REBOOTING 5
void connectToWiFi() // Connect to WiFi. Reboot on repeated failure
WiFi.persistent ( false ); // Don't save anything in EEPROM or LittleFS
WiFi.mode ( WIFI_STA ); // Station mode
// Count the number of WiFi connection retries
int WiFiTries = 0;
Serial.println ( "******************* connectToWifi using Static SSID/Pswd *****************" );
// Register THREE multi WiFi networks
wifiMulti.addAP ( MY_WIFI_SSID, MY_WIFI_PASSWORD );
wifiMulti.addAP ( MY_WIFI_SSID2, MY_WIFI_PASSWORD2 );
if ( MY_WIFI_SSID3 != "" ) wifiMulti.addAP ( MY_WIFI_SSID3, MY_WIFI_PASSWORD3 );
// Test for WiFi connectivity. Reboot after 5 tries.
while ( wifiMulti.run ( connectTimeoutMs ) != WL_CONNECTED )
WiFiTries++;
Serial.print ( "WiFi not connected... #" ); Serial.println ( WiFiTries );
if ( WiFiTries >= WIFI_RETRIES_BEFORE_REBOOTING )
Serial.println ( "RESTARTING! Cannot connect to WiFi\n\n" );
delay ( 5000 );
ESP.restart();
delay ( WIFI_RETRY_CONNECT_INTERVAL ); // This delay is ok for OTA and Blynk prior to WiFi connection
// Tell the world we are connected to WiFi
Serial.print ( "WiFi connected on attempt #" + String ( WiFiTries + 1 ) + " just fine to ");
Serial.print ( WiFi.SSID() ); Serial.print ( " at " ); Serial.println ( WiFi.localIP() ); Serial.println();
Serial.println();
End of Code.
Now, the #include files
I use #include files to keep my Blynk and WiFi credentials out of my code. Here are two examples for the XIAO code, above:
// #include "MY_WIFI_CREDENTIALS.h" // #defines MY_WIFI_SSID AND MY_WIFI_PASSWORD
#define MY_WIFI_SSID "myPrimarySSID" // network SSID (name)
#define MY_WIFI_PASSWORD "myPassword" // network password
// Use as a backup SSID if #1 fails so I can use my phone to reconnect, reprogram when needed
#define MY_WIFI_SSID2 "myNextSSID" // network SSID (name)
#define MY_WIFI_PASSWORD2 "AnotherPSWD" // network password
// Can add a 3rd SSID and password here... (but must have 3 in total)
#define MY_WIFI_SSID3 "" // network SSID (name)
#define MY_WIFI_PASSWORD3 "passowordo" // network password
// for diagnostic and heartbeat use
// WiFi.status ( return codes )
const char *myWiFiStatus[8] = { "0-WL_IDLE_STATUS", "1-WL_NO_SSID_AVAIL", "2-UNKNOWN",
/* for use in heartbeat*/ "3-WL_CONNECTED", "4-WL_CONNECT_FAILED", "5-UNKNOWN",
"6-WL_CONNECT_WRONG_PASSWORD",
"7-WL_DISCONNECTED" };
0 : WL_IDLE_STATUS when Wi-Fi is in process of changing between statuses
1 : WL_NO_SSID_AVAILin case configured SSID cannot be reached
3 : WL_CONNECTED after successful connection is established
4 : WL_CONNECT_FAILED if connection failed
6 : WL_CONNECT_WRONG_PASSWORD if password is incorrect
7 : WL_DISCONNECTED if module is not configured in station mode
Useful commands
WiFi.printdiag ( Serial ); lots of stuff, (not RSSI)
//#include "MY_BLYNK_CREDENTIALS.h" // #defines MY_BLYNK_SERVER and MY_xxx_AUTHCODE
#define MY_BLYNK_SERVER "blynk.cloud" // Common to all New Blynk sketches
#ifndef BLYNK_FIRMWARE_VERSION
#define BLYNK_FIRMWARE_VERSION "1.2.3"
#endif
//#define BLYNK_USE_128_VPINS true // Gives codes for VPINS up to V127
// These are dummy Template IDs and Device Authcode for the XIAO demonstration
// 6 //
#define MY_XIAO_RELAY_TEMPLATE_ID "TMPL2aaaaaaaa" // Use YOUR credentials
#define MY_XIAO_RELAY_TEMPLATE_NAME "XIAO Relay Template"
#define MY_XIAO_RELAY_DEVICE_AUTHCODE "yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy"
// ADDED June 2026
// ************** DUMMY TEMPLATE **************
// 99 //
// THESE ARE DUMMY SETTINGS FOR MY STARTUP TEMPLATE IN EXAMPLES
#define MY_STARTUP_TEMPLATE_ID "XXXXXXXXXXXX" // My Blynk Startup Template in Examples
#define MY_STARTUP_TEMPLATE_NAME "Startup Template"
#define MY_STARTUP_DEVICE_AUTHCODE "yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy"
Screenshot of a very simple Blynk app
Again, I hope this is useful.
