My Libraries are at latest version even the boards are already updated.
I am using A9G GSM and GPRS module and Xiao ESP32C3.
I wanted to connect to blynk without using wifi so I used this code below.
I selected A7 as my modem.
ESP32, Arduino, Raspberry Pi and the likes over the Internet.
You can easily build mobile and web interfaces for any
Downloads, docs, tutorials: https://www.blynk.io
Sketch generator: https://examples.blynk.cc
Blynk community: https://community.blynk.cc
Follow us: https://www.fb.com/blynkapp
https://twitter.com/blynk_app
Attention! Please check out TinyGSM guide:
https://tiny.cc/tinygsm-readme
Change GPRS apm, user, pass, and Blynk auth token to run :)
/* Fill in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID "*****"
#define BLYNK_TEMPLATE_NAME "*****"
#define BLYNK_AUTH_TOKEN "*****"
// Select your modem:
//#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[] = "gomo.ph";
char user[] = "";
char pass[] = "";
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
// Set GSM module baud rate
SerialAT.begin(9600, SERIAL_8N1, D5, D6);
delay(3000);
// modem.restart();
modem.init();
// Unlock your SIM card with a PIN
//modem.simUnlock("1234");
Blynk.begin(BLYNK_AUTH_TOKEN, modem, apn, user, pass);
But the output is like this
Please help me thank you!
