Good Afternoon,
I am currently working with an Arduino Nano, A ESP8266 wifi Chip, and Blynk on Andriod 7.1.1
Blynk Server Library 2.18.1
I need some help getting some base code set and then hopefully I can continue off that,
What I would like to do is be able to control my LED strip by changing the color as well as being able to set patterns on the go.
there are a few example sketches that I would like to pull some palettes from.
• Add your sketch code. Code should be formatted as example below.
#include <FastLED.h>
#define LED_PIN 6
#define NUM_LEDS 240
#define BRIGHTNESS 64
#define LED_TYPE WS2811
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
void setup() delay( 3000 ); // power-up safety delay
FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
FastLED.setBrightness( BRIGHTNESS );
currentPalette = RainbowColors_p;
currentBlending = LINEARBLEND;
ChangePalettePeriodically();
static uint8_t startIndex = 0;
startIndex = startIndex + 1; /* motion speed */
FillLEDsFromPaletteColors( startIndex);
FastLED.show();
FastLED.delay(1000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
uint8_t brightness = 255;
for( int i = 0; i < NUM_LEDS; i++) {
leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
colorIndex += 3;
Currently, this code just loops through all of the palettes I would like to control the palettes via a separate button in blynk and also have an all off button option. I would also like the ability to make the whole strip a solid color with a color wheel. If parts of code have been written else where please don’t hesitate to point them out to me.
Thank You for your assistance,
Kris
