The main loop doesn’t run …
And your sketch is?..
So here ist essential part of it
#include <Ethernet.h>
char auth[] = "xxxxx";
// Check connection every 30s
void reconnectBlynk() {
if (!Blynk.connected()) {
Serial.println("Lost connection");
if(Blynk.connect()) {
Serial.println("Reconnected");
else {
Serial.println("Not reconnected");
Serial.begin(115200); // Schnittstelle zum PC
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
// Timer definition
timer.setInterval(30000L, reconnectBlynk); // check every 30s if still connected to
// ************************ LOOP *******************************
Serial.print("Hello\n");
tried Version 5.4. and it works on WIFI (nano) but I did not get it run with Ethernet shield W5100
Having this in the void loop() running thousands of times a second is unnecessary, and potentially bad for the Blynk communication timing.
As for the rest… well… nothing is there, what are you doing?
PS, running connection routines while using Blynk.begin() is a bit counter productive as that is a blocking command, preventing the code from running if there is no server connection. Look at first setting up your ethernet connection then using Blynk.config() instead.
You are right , but the “Serial.print(“Hello\n”);” replesents just an example - not in real code, but even this does not work
even it does not come to the point that this is line of code is executed
You don’t even have these, or your ethernet, pins defined… how is it supposed to connect to your Ethernet ![]()
I think you should start with a simple example…
thanks for the note - I don’t want to overload you with details - if I would have not defined these it would even not work with version 5.0 I assume
THANKS for your time
Actually, without proper details and full code at the beginning, it is more a waste of our time.
SOLVED
This works:
Blynk.begin(auth, "blynk-cloud.com", 80);
this not
Blynk.begin(auth);
Hmm, generally the cloud and port are internally defaulted too by the Blynk Library, if not externally referenced… perhaps just a quirk with the ethernet connection? Regardless… working is working
