Not sure don’t use video.
Again it is covered in the DOCS, and there have been numerous postings about the video widget. Try to read a bit and learn.
You are welcome, but from now on you will be on your own with regards to step by step help (at least from me). Most of what I helped you with can be figured out with a little bit of research. As I have suggested, take some time to watch some YouTube videos on programming, read about programming basics on Google, read through and understand the DOCS, work through some of the examples on the Sketch Builder, familiarize yourself with the different widgets and how to use them, and search through the community for similar topics/issues. There are many examples of working WifiManager code, suggestions on which pins to stay away from, and lots of other helpful information and tips on the community forum. That little magnifying glass on the top right of the screen is a very powerful tool in itself.
Ok, vou me aprofundar mais.
Muito obrigado mesmo, me ajudou muito.
#include <FS.h> //this needs to be first, or it all crashes and burns...
//#define BLYNK_DEBUG // Comment this out to disable debug and save space
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
//for LED status
#include <Ticker.h>
Ticker ticker;
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
char blynk_token[34] = "BLYNK_TOKEN";
bool shouldSaveConfig = false; //flag for saving data
void checkPhysicalButton1();
void checkPhysicalButton2();
void checkPhysicalButton3();
void tick()
//toggle state
int estadorele1 = LOW;
int estadorele2 = LOW;
int estadorele3 = LOW;
int estadobotao1 = HIGH;
int estadobotao2 = HIGH;
int estadobotao3 = HIGH;
//int state = digitalRead(BUILTIN_LED); // get the current state of GPIO1 pin
// digitalWrite(BUILTIN_LED, !state); // set pin to the opposite state
BLYNK_CONNECTED()
Blynk.syncVirtual(V1);
Blynk.syncVirtual(V2);
Blynk.syncVirtual(V3);
BLYNK_WRITE(V1)
estadorele1 = param.asInt();
digitalWrite(5, estadorele1);
if (digitalRead(12) == LOW)
if(estadobotao1 != LOW)
estadorele1 = !estadorele1;
digitalWrite(5,estadorele1);
Blynk.virtualWrite(V1, estadorele1);
estadobotao1 = LOW;
BLYNK_WRITE(V2)
estadorele2 = param.asInt();
digitalWrite(4, estadorele2);
if (digitalRead(14) == LOW)
if(estadobotao2 != LOW)
estadorele2 = !estadorele2;
digitalWrite(4,estadorele2);
Blynk.virtualWrite(V2, estadorele2);
estadobotao2 = LOW;
BLYNK_WRITE(V3)
estadorele3 = param.asInt();
digitalWrite(2, estadorele3);
if (digitalRead(16) == LOW)
if(estadobotao3 != LOW)
estadorele3 = !estadorele3;
digitalWrite(2,estadorele3);
Blynk.virtualWrite(V3, estadorele3);
estadobotao3 = LOW;
void saveConfigCallback () //callback notifying us of the need to save config
Serial.println("Should save config");
shouldSaveConfig = true;
ticker.attach(0.2, tick); // led toggle faster
Serial.println();
//set led pin as output
//pinMode(BUILTIN_LED, OUTPUT);
pinMode(12, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
pinMode(16, INPUT_PULLUP);
pinMode(2, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
timer.setInterval(100L, checkPhysicalButton1);
timer.setInterval(100L, checkPhysicalButton2);
timer.setInterval(100L, checkPhysicalButton3);
// start ticker with 0.5 because we start in AP mode and try to connect
ticker.attach(0.6, tick);
//SPIFFS.format(); //clean FS, for testing
Serial.println("Mounting FS..."); //read configuration from FS json
if (SPIFFS.begin()) {
Serial.println("Mounted file system");
if (SPIFFS.exists("/config.json")) {
//file exists, reading and loading
Serial.println("Reading config file");
File configFile = SPIFFS.open("/config.json", "r");
if (configFile) {
Serial.println("Opened config file");
size_t size = configFile.size();
// Allocate a buffer to store contents of the file.
std::unique_ptr<char[]> buf(new char[size]);
configFile.readBytes(buf.get(), size);
DynamicJsonBuffer jsonBuffer;
JsonObject& json = jsonBuffer.parseObject(buf.get());
json.printTo(Serial);
if (json.success()) {
Serial.println("\nparsed json");
strcpy(blynk_token, json["blynk_token"]);
Serial.println("Failed to load json config");
Serial.println("Failed to mount FS");
//end read
// The extra parameters to be configured (can be either global or just in the setup)
// After connecting, parameter.getValue() will get you the configured value
// id/name placeholder/prompt default length
WiFiManagerParameter custom_blynk_token("blynk", "blynk token", blynk_token, 33); // was 32 length
Serial.println(blynk_token);
//WiFiManager
//Local intialization. Once its business is done, there is no need to keep it around
WiFiManager wifiManager;
wifiManager.setSaveConfigCallback(saveConfigCallback); //set config save notify callback
//set static ip
// this is for connecting to Office router not GargoyleTest but it can be changed in AP mode at 192.168.4.1
//wifiManager.setSTAStaticIPConfig(IPAddress(192,168,10,111), IPAddress(192,168,10,90), IPAddress(255,255,255,0));
wifiManager.addParameter(&custom_blynk_token); //add all your parameters here
//wifiManager.resetSettings(); //reset settings - for testing
//set minimu quality of signal so it ignores AP's under that quality
//defaults to 8%
//wifiManager.setMinimumSignalQuality();
//sets timeout until configuration portal gets turned off
//useful to make it all retry or go to sleep, in seconds
wifiManager.setTimeout(600); // 10 minutes to enter data and then Wemos resets to try again.
//fetches ssid and pass and tries to connect, if it does not connect it starts an access point with the specified name
//and goes into a blocking loop awaiting configuration
if (!wifiManager.autoConnect("CentralHeatingAP", "MY123PWD")) {
Serial.println("Failed to connect and hit timeout");
delay(3000);
//reset and try again, or maybe put it to deep sleep
ESP.reset();
delay(5000);
Serial.println("Connected Central Heating System :)"); //if you get here you have connected to the WiFi
ticker.detach();
//turn LED off
digitalWrite(BUILTIN_LED, HIGH);
strcpy(blynk_token, custom_blynk_token.getValue()); //read updated parameters
if (shouldSaveConfig) { //save the custom parameters to FS
Serial.println("saving config");
JsonObject& json = jsonBuffer.createObject();
json["blynk_token"] = blynk_token;
File configFile = SPIFFS.open("/config.json", "w");
if (!configFile) {
Serial.println("Failed to open config file for writing");
json.printTo(configFile);
configFile.close();
//end save
Serial.println("local ip");
Blynk.config(blynk_token);
//Blynk.connect();
Now it’s right?
thanks.
char blynk_token[] = "";
//char auth[] = "";
//char ssid[] = "";
//char pass[] = "";
//SimpleTimer timer;
Blynk.connect()
BLYNK_WRITE(V1)
estadobotao1 = LOW;
BLYNK_WRITE(V2)
estadobotao2 = LOW;
BLYNK_WRITE(V3)
estadobotao3 = LOW;
// wifi
wifiManager.autoConnect("AutoConnectAP", "ronin");
Serial.println("baglanti tamam :)");
WiFiManagerParameter custom_blynk_token("Blynk", "blynk token", blynk_token, 34);
wifiManager.autoConnect("Blynk");
Blynk.config(custom_blynk_token.getValue());
pinMode(2, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
bool result = Blynk.connect(180);
if (result != true)
Serial.println("BLYNK Connection Fail");
ESP.reset();
delay (5000);
Serial.println("BLYNK Connected");
Tentei mandar formatado de novo, o exemplo que você me indicou é com MQTT como altero para funcionar com a plataforma do blynk?
Tentei compilar o código que você me indicou e está da este erro
na imagem abaixo.
Aqui funciona normal, veja se você inclui todas as bibliotecas necessárias.
1
porque está dando este erro?
Como eu disse anteriormente, cheque se você adicionou todas as biblioteca requeridas por esse código que esta tentando usar.
Se você procurar aqui vai encontrar vários exemplos de códigos usando o WiFi Manager, porem eh uma funcao mais avancada.
Se voce apenas quer colocar para ajudar na hora de mudar sua senha do Wifi acho que nao vale a pena visto que voce nao muda sua senha tao frequentemente.
1
Blynk_CoeurRegular
luciano0609:
problem comes from the version of ArduinoJson used. (v6 beta)
you can not use this version with wifimanager
you need to install version 5.13
Olá Alexis, tudo bem!
Obrigado esta parte consegui resolver, agora e o meu código que estou tentando incluir neste código, não estou conseguindo.
Poderia me ajudar?
Blynk_CoeurRegular
luciano0609:
Poderia me ajudar?
Olá Luciano,
Yes I can try to help you,
please send us the code to insert , don’t forget backtips ```
//for LED status
#include <Ticker.h>
Ticker ticker;
void tick()
//toggle state
BLYNK_CONNECTED()
BLYNK_WRITE(V1)
estadobotao1 = LOW;
BLYNK_WRITE(V2)
estadobotao2 = LOW;
BLYNK_WRITE(V3)
estadobotao3 = LOW;
Serial.println();
pinMode(2, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
if (configFile) {
//end read
//WiFiManager
//set static ip
//defaults to 8%
delay(3000);
ESP.reset();
delay(5000);
ticker.detach();
//turn LED off
if (!configFile) {
configFile.close();
//end save
//Blynk.connect();
