Hardware: ESP-8266
Core Version: 3.0.2 staging
Arduino IDE: 1.8.9
May very simple sketch is compiled with error: WiFiManager.cpp:1319:35: error: ‘HTTPAuthMethod’ has not been declared 1319 | server->requestAuthentication(HTTPAuthMethod::BASIC_AUTH); // DIGEST_AUTH
There is sketch:
@klg Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
This doesn’t seem to be a Blynk related question, as you have no Blynk libraries or Blynk code in your sketch.
You also seem to be missing a lot of WiFi manager related code from your sketch.
If you wnat to use WiFiManager with Blynk then I’d suggest you look at the WiFiManager examples on the WiFiManager GitHub page.
But, you don’t really need to use WiFiManager with Blynk. You’d be far better using the Blynk Edgent example, which allows dynamic provisioning of the WiFi credentials via the Blynk app.
But in these case will be compile included libraries. If compilator report Errors it means something is wrong with the libraries. This is what I don’t understand.
