Can not adjust the temperature +/- online. I solved the coil to adjust the temperature online.
//#include <SimpleTimer.h>
//SimpleTimer timer;
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#include "DHT.h"
DHT dht;
int sett;
double settemp;
double temperature;
int humidity;
int Relay1=D7;
int Relay2=D8;
int Relay3=D9;
int Relay4=D10;
int sensorcurrentCount1,sensorbeforeCount1,sensor_Count1;
int sensorcurrentCount2,sensorbeforeCount2,sensor_Count2;
int sensorcurrentCount3,sensorbeforeCount3,sensor_Count3;
byte termometru[8] = //icon for termometer
B00100,
B01010,
B01010,
B01110,
B01110,
B11111,
B11111,
B01110
byte picatura[8] = //icon for water droplet
B00100,
B00100,
B01010,
B01010,
B10001,
B10001,
B10001,
B01110,
char auth[] = "791f0f79e650499b9412ac9daad152ef";
Blynk.begin(auth, "saplai", "123456789");
// timer.setInterval(5000L, sendUptime);
Serial.println();
Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
pinMode(Relay1,OUTPUT);
pinMode(Relay2,OUTPUT);
pinMode(Relay3,OUTPUT);
pinMode(Relay4,OUTPUT);
pinMode(D5,INPUT);
pinMode(D6,INPUT);
pinMode(D4,INPUT);
sett=0;
sensor_Count1=D4;
sensorbeforeCount1=HIGH;
sensor_Count2=D6;
sensorbeforeCount2=HIGH;
sensor_Count3=D5;
sensorbeforeCount3=HIGH;
settemp=0;
lcd.begin(); // initialize the lcd
lcd.begin();
lcd.backlight();
lcd.createChar(1,termometru);
lcd.createChar(2,picatura);
lcd.setCursor(0,0);
lcd.write(1);
lcd.setCursor(7, 0);
lcd.print("C");
lcd.setCursor(10,0);
lcd.write(2);
lcd.setCursor(15,0);
lcd.print("%");
lcd.setCursor(0,1);
lcd.print("S:");
lcd.setCursor(2,1);
lcd.write(1);
digitalWrite(Relay1,LOW);
digitalWrite(Relay2,LOW);
digitalWrite(Relay3,LOW);
digitalWrite(Relay4,LOW);
dht.setup(D3); //
temperature = dht.getTemperature(); // ดึงค่าอุณหภูมิ
settemp=29.00;
// V0=29;
TEMP();
SwCounting3();
SwCounting1();
SwCounting2();
SwCounting3();
lcd.setCursor(3,1);
lcd.print(settemp );
lcd.setCursor(8, 1);
lcd.print("C");
Blynk.setProperty(V7, settemp=settemp+0.1, "ON");
Blynk.setProperty(V8, settemp=settemp-0.1, "ON");
set(settemp);
lcd.setCursor(3,1);
lcd.print("C");
Blynk.virtualWrite(V5, temperature);
Blynk.virtualWrite(V6, humidity);
lcd.setCursor(0,0);
lcd.write(1);
lcd.print("C");
lcd.write(2);
lcd.print("%");
lcd.setCursor(14,0);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("S:");
lcd.setCursor(2,1);
lcd.write(1);
void TEMP(){ //ชุดคำสั่งอุณหภูมิ
humidity = dht.getHumidity(); // ดึงค่าความชื้น
lcd.setCursor(12, 0);
lcd.print(humidity);
Serial.print(humidity);
lcd.setCursor(2, 0);
lcd.print(temperature,2);
Serial.print(temperature,1);
void set(float temp){
if(temperature>=(temp+0.5)){
lcd.setCursor(10,1);
lcd.print("TEMP-");
digitalWrite(Relay1,HIGH);
digitalWrite(Relay2,HIGH);
//lcd.clear();
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
led1.on();
led2.on();
led3.off();
else if(temperature<=(temp-0.5)){
lcd.print("TEMP+");
digitalWrite(Relay3,HIGH);
WidgetLED led1(V1);
WidgetLED led2(V2);
WidgetLED led3(V3);
led1.off();
led2.on();
led3.on();
//lcd.clear();
else if(temperature==temp){
WidgetLED led1(V1);
led1.off();
WidgetLED led2(V2);
led2.off();
WidgetLED led3(V3);
led3.off();
lcd.print(" ");
void SwCounting1(void)
sensorcurrentCount1 = digitalRead(sensor_Count1);
if ((sensorbeforeCount1 !=0 && sensorcurrentCount1==0 ))
settemp=settemp+0.1;
sensorbeforeCount1 = sensorcurrentCount1;
void SwCounting2(void)
sensorcurrentCount2 = digitalRead(sensor_Count2);
if ((sensorbeforeCount2 !=0 && sensorcurrentCount2==0 ))
settemp=settemp-0.1;
sensorbeforeCount2 = sensorcurrentCount2;
void SwCounting3(void)
sensorcurrentCount3 = digitalRead(sensor_Count3);
if ((sensorbeforeCount3 !=0 && sensorcurrentCount3==0 ))
if(sett==2){ sett=0;
lcd.print(" ");}
else sett=sett+1;
sensorbeforeCount3 = sensorcurrentCount3;
