• Hardware mode: Custom ESP32 Board - WiFi
• Blynk server: blynk.cloud:433
• Blynk Library version: 1.0.1
Suddenly out of nowhere, the firmware I’ve been writing won’t connect to WiFi over SSL, I’ve copied down the default ESP32 SSL firmware and getting similar results. Down below you can see the output of the code.
I’m using the Blynk Endget app and it suddenly stopped working. I’ve tried restarting the router, connecting to a mobile hotspot and tried the non SSL version which worked. However, the Endget will not work without the SSL version it seems.
I don’t seem to be able to ping blynk.cloud:433
You’ll need:
- Blynk IoT app (download from App Store or Google Play)
- ESP32 board
example.
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32_SSL.h>
char pass[] = "YourPassword";
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 443);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8443);
// to avoid delay() function!
Log:
30] Connecting to Q-light
[ 49][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 0 - WIFI_READY
[ 143][V][WiFiGeneric.cpp:272] _arduino_event_cb(): STA Started
[ 146][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 2 - STA_START
[ 166][V][WiFiGeneric.cpp:96] set_esp_interface_ip(): Configuring Station static IP: 0.0.0.0, MASK: 0.0.0.0, GW: 0.0.0.0
[ 2260][V][WiFiGeneric.cpp:284] _arduino_event_cb(): STA Connected: SSID: Q-light, BSSID: 74:83:c2:27:88:4d, Channel: 11, Auth: WPA2_PSK
[ 2261][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 4 - STA_CONNECTED
[ 2299][V][WiFiGeneric.cpp:294] _arduino_event_cb(): STA Got New IP:10.0.0.10
[ 2299][D][WiFiGeneric.cpp:831] _eventCallback(): Arduino Event: 7 - STA_GOT_IP
[ 2302][D][WiFiGeneric.cpp:880] _eventCallback(): STA IP: 10.0.0.10, MASK: 255.255.255.0, GW: 10.0.0.138
[2674] Connected to WiFi
[2674] IP: 10.0.0.10
[2674]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.0.1 on ESP32
[ 2684][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
[ 2686][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
[2703] Connecting to blynk.cloud:443
[ 2703][V][ssl_client.cpp:61] start_ssl_client(): Free internal heap before TLS 268384
[ 2704][V][ssl_client.cpp:67] start_ssl_client(): Starting socket
[ 3000][V][ssl_client.cpp:143] start_ssl_client(): Seeding the random number generator
[ 3002][V][ssl_client.cpp:152] start_ssl_client(): Setting up the SSL/TLS structure...
[ 3006][V][ssl_client.cpp:175] start_ssl_client(): Loading CA cert
[ 3178][V][ssl_client.cpp:244] start_ssl_client(): Setting hostname for TLS session...
[ 3179][V][ssl_client.cpp:259] start_ssl_client(): Performing the SSL/TLS handshake...
[ 3191][E][WiFiClientSecure.cpp:135] connect(): start_ssl_client: -1
[ 3194][V][ssl_client.cpp:311] stop_ssl_socket(): Cleaning SSL connection.
[3207] Secure connection failed
