Wifi problems - Arduino Uno R3 with Grove Hat and Grove UART WiFi V2 (ESP8285)
Hello, I’m having trouble connecting to a wi-fi network with Blynk. My project is a prototype environmental monitor for a local junior high school STEM/robotics class.
Hardware is:
//Arduino Uno R3
//Grove Base Shield V2.0 for Arduino
// A0 = “Grove-Loudness Sensor” Based on amplifier LM2904 & built-in microphone SeedStudio SKU 101020063
// A1 = “Grove Sound Sensor”; Grove - Sound Sensor Based on LM358 amplifier - Arduino Compatible SeedStudio SKU 101020023
// A2 = “Grove - Air quality sensor Grove - Air Quality Sensor v1.3 - Arduino Compatible” SeedStudio SKU: 101020078
// I2C = “Grove - Temp&Humi Sensor” DHT20 I2C port - SeedStudio SKU 101020932
// D6 = Grove - UART WiFi V2 (ESP8285) SeedStudio SKU: 113020011
I’m using the Arduino IDE, Blynk server , Blynk Library version 1.3.2. The quickstart example code doesn’t work:
  This is a simple demo of sending and receiving some data.
  Be sure to check out other examples!
/* Fill-in information from Blynk Device Info here */
#define BLYNK_TEMPLATE_ID           "***"
#define BLYNK_TEMPLATE_NAME         "Quickstart Template"
#define BLYNK_AUTH_TOKEN            "***"
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
char ssid[] = "***";  // your network SSID (name)
char pass[] = "***";    // your network password
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
  // Set incoming value from pin V0 to a variable
  int value = param.asInt();
  // Update state
  Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V3, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  Blynk.virtualWrite(V2, millis() / 1000);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, "blynk.cloud", 80);
  //Blynk.begin(BLYNK_AUTH_TOKEN, ssid, pass, IPAddress(192,168,1,100), 8080);
  // to avoid delay() function!
This sketch simply returns:
[463] WiFi module not found
I do have the Arduino IDE verbose output enabled and it complied OK.
I did have connectivity before trying Blynk, using the following code:
#include "Arduino_SensorKit.h"
#include <Arduino_BuiltIn.h>
//uncomment line below if using DHT20
#define Environment Environment_I2C
// installed library https://github.com/bportaluri/WiFiEsp
#include "WiFiEsp.h"
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
int status = WL_IDLE_STATUS;    // the Wifi radio's status
const int pinAdc = A1;
int loudness;
//String airQualityHistory = "";
//Sensor Setup
//#define airquality_sensor_pin 0
  Wire.begin();
  Environment.begin();
  // initialize serial for ESP module
  Serial1.begin(9600);
  // initialize ESP module
  WiFi.init(&Serial1);
  // check for the presence of the shield
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue
    while (true);
  // attempt to connect to WiFi network
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WPA SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network
    status = WiFi.begin(ssid, pass);
  // you're connected now, so print out the data
  Serial.println("You're connected to the network");
  Serial.println();
    //Basic Loudness
    loudness = analogRead(0);
    Serial.print("Loudness Sensor: ");
    Serial.println(loudness);
    // delay(200);
    long sum = 0;
    for(int i=0; i<32; i++)
        sum += analogRead(pinAdc);
    sum >>= 5;
    Serial.print("Sound Sensor: ");
    Serial.println(sum);
    // DHT20
     // Reading temperature or humidity takes about 250 milliseconds!
    // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
    Serial.print("Temperature = ");
      Serial.print(Environment.readTemperature()); //print temperature
      Serial.println(" C");
      Serial.print("Humidity = ");
      Serial.print(Environment.readHumidity()); //print humidity
      Serial.println(" %");
      //delay(2000);
      Serial.println();
  // if debug then do these:
  //printCurrentNet();
  //printWifiData();
    delay(500);
void printWifiData()
  // print your WiFi shield's IP address
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print your MAC address
  byte mac[6];
  WiFi.macAddress(mac);
  char buf[20];
  sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", mac[5], mac[4], mac[3], mac[2], mac[1], mac[0]);
  Serial.print("MAC address: ");
  Serial.println(buf);
void printCurrentNet()
  // print the SSID of the network you're attached to
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print the MAC address of the router you're attached to
  byte bssid[6];
  WiFi.BSSID(bssid);
  char buf[20];
  sprintf(buf, "%02X:%02X:%02X:%02X:%02X:%02X", bssid[5], bssid[4], bssid[3], bssid[2], bssid[1], bssid[0]);
  Serial.print("BSSID: ");
  // print the received signal strength
  long rssi = WiFi.RSSI();
  Serial.print("Signal strength (RSSI): ");
  Serial.println(rssi);
Almost all the code snippets and forum posts use the older ESP8266 module…
Does anyone know if Blynk supports the “Grove - UART WiFi V2 (ESP8285)” module?
