I am working with an Arduino MKR 1010 wifi and Arduino MKR ENV shield. Sending environmental data to Blynk-App on iOS. It all works fine as long as I start serial plotter in Arduino IDE once - connection to wifi is established without issues. But when I try to let the MKR rund on its own - without Arduino IDE connect - just on USB power. There is no Wifi-Connection happening. MKR is obviously waiting for instigation of the Wifi connection via serial plotter.
http://twitter.com/blynk_app
This example shows how to use Arduino MKR 1010
to connect your project to Blynk.
Note: This requires WiFiNINA library
from http://librarymanager/all#WiFiNINA
// #define BLYNK_PRINT Serial
// #include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <Arduino_MKRENV.h>
char auth[] = „xxxx“;
char ssid[] = „xxxx“;
char pass[] = „xxxx“;
while (!Serial);
if (!ENV.begin()) {
Serial.println("Failed to initialize MKR ENV shield!");
while (1);
timer.setInterval(5000L, sendSensor);
void sendSensor()
float h = ENV.readHumidity();
float t = ENV.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
float lx = ENV.readLux();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Blynk.virtualWrite(V7, lx);
