Hello, I have big problems with my garden automation project. I built the system, written the code and created the app with Blynk. All the system works great, with no problems at all. The problems start after some time I have powered the Arduino MKR1010 WiFi, that controls all the sensors and the water valve. After some hours it disconnected, so i tried to move the Arduino (with nothing connected) nearer the router. The problem is always the same: it works perfectly, but after some hours or days it disconnects, and sometimes it reconnects, but other times NOT. It stays disconnected until I press the reset button on the board. When I reset it, it instantly reconnects, so my idea is to find a way to automatically reset the board when there is a disconnect, maybe using a board like an esp32 connected to the reset pin of the Arduino, or without other boards, it will be better. Is this possible? Is there any other way to make the Arduino to reconnect if it loses connection? Reading in the docs.blynk I have found that the server disconnects the hardware if it is offline for more than 15 seconds. Is that right? Is there any way to modify this time? Can a ethernet shield connected to a wifi antenna (connecting directly to the router is not possible, it is too far) be a solution? I need to solve this problem, because if it disconnects for a lot of time the plants don’t have the water and will die.
As written before, I use an Arduino MKR1010 WiFi. My phone is a Samsung M31 and it is pretty new.
Here is the code. As you can see the loop is clean.
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
char auth[] = " ";
char ssid[] = " ";
char pass[] = " ";
int controlloAllarme;
int controlloIrrigazione;
int timerIrrigazione;
int manualeIrrigazione;
int resetIrrigazione;
int ledIrrigazione;
void trasmissioneDati()
int sens5 = analogRead(A6);
int sens4 = analogRead(A5);
int sens3 = analogRead(A4);
int sens2 = analogRead(A3);
int sens1 = analogRead(A2);
int statoAllagamento = digitalRead(3);
Blynk.virtualWrite(V15, sens5);
Blynk.virtualWrite(V14, sens4);
Blynk.virtualWrite(V13, sens3);
Blynk.virtualWrite(V12, sens2);
Blynk.virtualWrite(V11, sens1);
if (statoAllagamento == LOW && controlloAllarme == 1)
Blynk.notify("ATTENZIONE: ALLARME ALLAGAMENTO ATTIVATO");
if ((timerIrrigazione == 1 || manualeIrrigazione == 1) && controlloIrrigazione == 1)
digitalWrite(4, LOW);
Blynk.virtualWrite(V8, 255);
digitalWrite(4, HIGH);
Blynk.virtualWrite(V8, 0);
pinMode(3, INPUT_PULLUP);
pinMode(4, OUTPUT);
timer.setInterval(2000L, trasmissioneDati);
BLYNK_WRITE(V2)
controlloAllarme = param.asInt();
BLYNK_WRITE(V4)
controlloIrrigazione = param.asInt();
BLYNK_WRITE(V5)
timerIrrigazione = param.asInt();
BLYNK_WRITE(V6)
manualeIrrigazione = param.asInt();
I hope there is a solution to my problem, thank you!
