WIDO V1.1 Compiling error!
I 'm using latest version of WIDO from DFRobot.
and im triyin to use Blynk app and Arudino sketch ‘BlynkLedTest-master’.
But the probloem is compiling error is occured for board Arduino Errors.
I Thought Wido V1.0 is works but My lates version is not working.
so can u check this issue for me? asap!!!
Here is my error message from Arduino 1.6.8
In file included from C:\Users\melon_000\Documents\Arduino\libraries\Blynk/BlynkSimpleCC3000.h:13:0,
                 from C:\Users\melon_000\Desktop\BlynkLedTest-master\BlynkLedTest-master\BlynkLedTest\BlynkLedTest.ino:23:
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h: In member function 'void BlynkTransportCC3000::disconnect()':
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:39:32: error: 'class Adafruit_CC3000_Client' has no member named 'stop'
     void disconnect() { client.stop(); }
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h: In member function 'size_t BlynkTransportCC3000::read(void*, size_t)':
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:42:23: error: 'class Adafruit_CC3000_Client' has no member named 'readBytes'
         return client.readBytes((char*)buf, len);
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h: At global scope:
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:132:14: error: 'IPAddress' has not been declared
              IPAddress   ip,
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:154:17: error: 'IPAddress' has not been declared
                 IPAddress   ip,
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h: In member function 'void BlynkCC3000::config(const char*, int, uint16_t)':
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:136:44: error: invalid types 'int[int]' for array subscript
         this->conn.begin(cc3000.IP2U32(ip[0],ip[1],ip[2],ip[3]), port);
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:136:50: error: invalid types 'int[int]' for array subscript
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:136:56: error: invalid types 'int[int]' for array subscript
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:136:62: error: invalid types 'int[int]' for array subscript
exit status 1
Error compiling for board Arduino Leonardo.
looks like you might have a library issue?
but hard to tell why this would be urgent?
Please use this example: https://github.com/blynkkk/blynk-library/blob/master/examples/BoardsAndShields/CC3000/CC3000.ino
and read instructions/comments carefully.
Hope that helps. Tell us how it goes - we may add a special example for it
Thanks for your help!
But it did not working.
I already did just like u said but the same compile errors occured.
(EX.
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h: In member function ‘void BlynkTransportCC3000::disconnect()’:
C:\Users\melon_000\Documents\Arduino\libraries\Blynk/Adapters/BlynkCC3000.h:39: error: ‘class Adafruit_CC3000_Client’ has no member named ‘stop’
etc.)
it means you’re using the wrong library - download by the link in sketch…
