it would be great to have an ‘index’ property method for widgets:
by default the index value is the main datastream number
if index is set, it overrides the main datastream number
for exemple:
- a ‘value display’ widget datastream is 12 : changing index value to 7 will immediately apply properties and value of datastream 7 and update widget display according to the new datastream
- series in a chart can be changed very easily
- … more other uses…
programmer must ensure datastreams are compatible
thanks a lot
