Hi, I use the WebPage Image Button widget on the Blynk iot app to display the below linked image.
https://community.blynk.cc/uploads/default/original/3X/9/7/97908720d77a501ecdd0efe329a41b7d654d3e55.png
This image is perfectly displayed on Android devices with the Blynk iot app in both Dark and Light theme mode, however on Apple devices this image is only displayed in Dark mode, so it is not visible to those who use the light mode.
Hi @seby ,
We will fix this error. You can go to the settings of this widget, then to Design, select Light , open the image, and save it again.
Dmitriy from Blynk
Hi Dmitriy when you put the Light mode on the iPhone the image link is not inserted, however if I go to dark I find the link inserted previously.
I inserted the link on light and in this way the image is visible.
