Hello friends. Im using ESP32 to control a relay. Everything is working OK inside blynk app. Problem is when i add a button widget at my Android phone homescreen. Widget does not work. Visually it changes state, but physically nothing happens. Am i missing anything?
Thank you
#include <BlynkSimpleEsp32.h>
// Blynk Auth Token.
// Go to the Project Settings (nut icon)in Blynk App.
char auth[] = "x";
char ssid[] = "x";
char pass[] = "x";
const int Relay_1 = 26;
BLYNK_WRITE(V1)
int pinValue = param.asInt();
if (pinValue == 1)
digitalWrite(Relay_1, HIGH);
Serial.println("Luz Ligada");
else if (pinValue == 0)
digitalWrite(Relay_1, LOW);
Serial.println("Luz Desligada");
BLYNK_CONNECTED() {
Blynk.syncAll();
pinMode(Relay_1, OUTPUT);
// Connect to Wi-Fi network with SSID and password
Serial.println(ssid);
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed!");
// Print local IP address
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
Blynk.config(auth, IPAddress(192,168,x,x), 8080);
