Nowadays i have three different hardwares using the same token but different virtual pins. With this configuration I can see all the information with only one App.
The thing is that I would like to display a value that is the addition of V1 + V2 + V3, where each Virtual pin comes from different Hardware. The workaround to do this, as far as i know is using a brige that reads information from different HW, makes calculations and then sends to Blynk. But i think it would be much simple to have a Widget to make easy calculations (addition, substraction, etc) between Virtual Pins…
Leandro
