Hello is there a way to make the font size on the widget like for example button more big so be able to see
There is no way to that at the moment.
I think it would be a good idea to do this!
Am using the display label to show the words bigger
I had not thought about it, I’ll test it and see how it goes.
And if using them that way and you don’t want the small white label showing as well, just put a space in the label field. It will then be blank when running the app.
