DebugSerial.begin(9600); // Debug console
// 9600 is for HC-06. For HC-05 default speed is 38400
Serial.begin(38400);
Blynk.begin(Serial, auth);
Ask Google how to read voltage on an Uno and add that to your sketch with BlynkTimer like in the PUSH_DATA example
char auth[] = "d8e1181a229a42c591ec12f6fc63ef90";
void myTimerEvent()
Blynk.virtualWrite(V0,analogRead(A0)*5.0/1023.0);
pinMode(A0,INPUT);
You shouldn’t need this at all… the ADC pins are by design, inputs… setting this may affect how it normally works?
PS, My experience with BT has been sketchy for even simple things like reading analog pins… not sure if it is an issue in the library or not, but I sometimes add in this line to disable direct App/pin manipulation and rely strictly on virtual pins.
#define BLYNK_NO_BUILTIN // Disable built-in analog & digital pin operations
