Hi all, please I need your help on this code. When without the connection of blynk command, I get value decibel range 35-60 . but when connecting with blynk, the value goes to thousand. anyone know how to solve?
#define BLYNK_TEMPLATE_ID ""
#define BLYNK_DEVICE_NAME ""
#define BLYNK_AUTH_TOKEN ""
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "";
char pass[] = "";
const int sampleWindow = 50; // Sample window width in mS (50 mS = 20Hz)
unsigned int sample;
const byte soundpin=4;
const byte led1= 2;
const byte led2= 17;
const byte led3= 18;
pinMode (soundpin,INPUT);
pinMode (led1,OUTPUT);
pinMode (led2,OUTPUT);
pinMode (led3,OUTPUT);
Serial.begin (115200);
unsigned long startMillis= millis();
float peakTopeak= 0;
unsigned int signalMax=0; // minvalue
unsigned int signalMin=1024; //maxvalue
while(millis() - startMillis < sampleWindow)
sample = analogRead(soundpin);
if (sample < 1024)
if (sample > signalMax)
signalMax = sample; //save just max level
else if(sample < signalMax)
signalMin = sample; //save just min level
peakTopeak = signalMax - signalMin;
int store = map(peakTopeak,20,900,49.5,90); //calibrate the db
int db= store-30;
Serial.print("\nLoudness: ");
Serial.print (db);
Serial.print ("Db(A)\t");
if (db<=37)
Serial.print("Levell: Quiet");
digitalWrite(led1, HIGH);
else if(db>37 && db<40)
Serial.print("Level2: Moderate");
digitalWrite(led2, HIGH);
else if(db>=40)
Serial.print("Level3: HIGH");
digitalWrite(led3, HIGH);
Blynk.virtualWrite(V0,db);
digitalWrite (led1,LOW);
digitalWrite (led2,LOW);
digitalWrite (led3,LOW);
what if I want to read the data from analog sensor, and do some calculation like calibrate first by mapping to get decibel values (range 0-120). should I do the analogread n do calibration in void sensorDatasend () function and end with blynk.virtualWrite(V0,db); then in void loop() {blynk.run(); timer.run();}?? I still faced the same number (thousand dbs)
Show us what results you are getting in your serial monitor (copy the serial monitor text and paste it between triple backticks - do not post screenshots) and what you are seeing in Blynk.
Show us how you have configured the V0 datastream, and how you’ve configured the widget attached to V0 in your app.
Also, post your modified code.
I’d suggest that you add more serial print statements so that you can monitor the values of the various variables, and Tim -on the timestamp in the serial monitor too.
I try to do simple coding, receive data from sensor and send to blynk app. When I do without connection of blynk, the serial monitor show range of result from 500-600. As I connect with blynk, 0 value remains. Can you help why?
Hi pete, Do you have any idea how to make the led light up for about 0.5 sec and OFF before new loop. If i used delay, then the reading will be affected ( huge number in result). same also if i put the digital write and blink virtual write at the top part.
void sensorDataSend() {
int sample;
unsigned long startMillis = millis();
float peakTopeak = 0;
int db;
unsigned int signalMax = 0; // minvalue
unsigned int signalMin = 1024; //maxvalue
while (millis() - startMillis < sampleWindow)
if (sample < 1024)
else if (sample < signalMax)
int store = map(peakTopeak, 20, 900, 49.5, 90); //calibrate the db
db = store - 17;
Serial.print (db);
Blynk.virtualWrite(V0, db);
if (db <= 37)
Blynk.virtualWrite(V1, 1);
else if (db > 37 && db < 40)
Blynk.virtualWrite(V2, 1);
else if (db >= 40)
Blynk.virtualWrite(V3, 1);
//delay(500); cannot place delay else high value shown up
digitalWrite (led1, LOW);
digitalWrite (led2, LOW);
digitalWrite (led3, LOW);
Blynk.virtualWrite(V1, 0);
Blynk.virtualWrite(V2, 0);
Blynk.virtualWrite(V3, 0);
You can use a Blynk timer in timeout timer mode, like this…
timer.setTimeout(500L, []()
// When the timer completes, any code here will be executed
// so put your code to turn off the LED in here
But, I suspect that’s not the best solution for you.
I think once you’ve taken your readings and are ready to display the results you would be better turning all three LED’s off, then turning the appropriate LED on, then leaving it on until the next batch of readings have been taken.
Also, you could emulate the old LED VU meter by lighting up the low and medium LEDs at the same time when you have a medium reading, and the low, medium and high LEDs when you have a high reading…
