#include <FS.h>
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h> //https://github.com/bblanchon/ArduinoJson
#include <DHT.h>
char blynk_token[34] = "BLYNK_TOKEN";
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback () {
Serial.println("Should save config");
shouldSaveConfig = true;
bool pirEnabled = false;
BLYNK_WRITE(V1){
int control4DigitalPins = param.asInt();
if(control4DigitalPins == 1){
digitalWrite(D1, HIGH);
digitalWrite(D2, HIGH);
digitalWrite(D3, HIGH);
digitalWrite(D7, HIGH);
else{
digitalWrite(D1, LOW);
digitalWrite(D2, LOW);
digitalWrite(D3, LOW);
digitalWrite(D7, LOW);
BLYNK_WRITE(V3){ // button in switch mode
if(param.asInt()){
pirEnabled = true;
else{
pirEnabled = false;
#define DHTPIN 2 // What digital pin we're connected to
#define ledPower 16
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
int h = dht.readHumidity();
int t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
int p=digitalRead(14);
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
if((p==HIGH) && (pirEnabled == true)){
Blynk.notify("Orang Tak Dikenal Terdeteksi");
pinMode (ledPower,OUTPUT);
digitalWrite (ledPower, HIGH);
pinMode(14,INPUT);
//SPIFFS.format(); //clean FS, for testing
Serial.println("Mounting FS..."); //read configuration from FS json
My board uses Nodemcu Lolin V3 with wifi manager : Why does my pir sensor always give motion detection notifications continuously doesn’t stop when the V3 button is on?
when the V3 button is off, it works great because the PIR Sensor is off…
can anyone here help me, please?
Thankyou
