Hi guys,
Have problems to progam a sketch, where a led fade automatically up and down, but where I can adjust the time with a slider, in which it does it. Below my sketch and the error I get in Serial Monitor, when I change timer interval. I don´t know why, but when I try to adjust the “speed” appear the error and I get kicked from Blynk server? It´s possible that it interrelate with the power supply (read something on web) but it would be strange, because until now I never had any problems with the power supply from my PC
BlynkTimer timerSzene;
WidgetLED ledV101 (V101);
char auth[] = "3cfd6fa8eada49b08478d9b9062ba312";
char ssid[] = "Fritzbox3272";
char pass[] = "67033709486218110510";
int timerID_Szene = 0;
int LedPinD1 = D1;
int Control_Szene = 0;
int varButtonV2 = 0;
int OutputValue_Szene = 0;
int SzeneSteps = 5;
timerSzene.run();
pinMode (LedPinD1, OUTPUT);
timerID_Szene = timerSzene.setInterval(1000L, Func_Mode_Szene);
BLYNK_WRITE(V26)
Control_Szene = param.asInt();
if (varButtonV2 == 1) {
timerSzene.deleteTimer(timerID_Szene);
timerID_Szene = timerSzene.setInterval(1L / Control_Szene, Func_Mode_Szene);
BLYNK_WRITE(V2)
int ButtonV2 = param.asInt();
if (ButtonV2 == 1) {
timerSzene.enable(timerID_Szene);
if (ButtonV2 == 0) {
timerSzene.disable(timerID_Szene);
void Func_Mode_Szene() {
ledV101.setValue(OutputValue_Szene);
analogWrite(LedPinD1, OutputValue_Szene);
static int SzeneValue = 0;
SzeneValue = SzeneValue + SzeneSteps;
if (SzeneValue > 255 || SzeneValue < 0) {
SzeneSteps = -SzeneSteps;
OutputValue_Szene = SzeneValue;
Serial.print("SzeneValue = ");
Serial.println(SzeneValue);
[11326] Connecting to blynk-cloud.com:80
[11468] Ready (ping: 73ms).
SzeneValue = 5
SzeneValue = 10
SzeneValue = 15
Exception (0):
epc1=0x4000e25d epc2=0x00000000 epc3=0x4020db34 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff0410 end: 3fff0620 offset: 01a0
>>>stack>>>
3fff05b0: 00000000 3ffef2b8 3ffef294 40204509
3fff05c0: 00004ad2 00000000 00004ad2 00000000
3fff05d0: 00000001 00000002 3ffef538 3ffef5f8
3fff05e0: 000018b4 00000000 3ffef294 3ffef5f8
3fff05f0: 3fffdad0 00000000 3ffef5f0 40203369
3fff0600: 3fffdad0 00000000 3ffef5f0 40204d58
3fff0610: feefeffe feefeffe 3ffef600 40100710
<<<stack<<<
