I use the BlynkTimer timer; To send the information according to the code I have put but it only works BLYNK data of PowerMeter not send data and not connected to the power meter
My normal code can be used for the information Power meter.
#define MAX485_DE D6
#define MAX485_RE_NEG D6
#define RO_RX D2
#define DI_TX D3
float voltage1,voltage2, current, power, energy, frequency, pf;
SoftwareSerial mySerial(RO_RX, DI_TX);
ModbusMaster node;
float C1,C2,C3;
float V1,V2,V3;
float KWh;
float KW;
float HZ;
float PF1,PF2,PF3;
int lock = 0;
void preTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
Serial.begin(19200);
mySerial.begin(19200);
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Serial2.begin(9600, SERIAL_8N1, 16, 17);
node.begin(1,mySerial);
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
Serial.println("Test Cirduit Breaker Start");
uint8_t result1,result2,result3,result4;
uint16_t data1[0],data2[0],data3[0],data4[0];
result1 = node.readInputRegisters(0000,2);
if (result1 == node.ku8MBSuccess)
data1[0] = node.getResponseBuffer(1);
voltage1 = data1[0]/100;
Serial.print("v1 : ");
Serial.println(voltage1);
result2 = node.readInputRegisters(0006,2);
if (result2 == node.ku8MBSuccess)
data2[0] = node.getResponseBuffer(1);
voltage2 = data2[0]/100;
Serial.print("v2 : ");
Serial.println(voltage2);
***and this code The code I added BLYNK and I can't see the data Power meter.***
```#include <ModbusMaster.h>
#define RO_RX D2
#define DI_TX D3
#define BLYNK_TEMPLATE_ID "TMPLi-uUIJ26"
#define BLYNK_DEVICE_NAME "new"
#define APP_DEBUG
int lock = 0;
ModbusMaster node;
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_SPARKFUN_BLYNK_BOARD
#define USE_NODE_MCU_BOARD
//#define USE_WITTY_CLOUD_BOARD
//#define USE_WEMOS_D1_MINI
#include "BlynkEdgent.h"
void myTimerEvent1()
float voltage1;
Blynk.virtualWrite(V1, voltage1);
void myTimerEvent2()
float voltage2;
Blynk.virtualWrite(V2, voltage2);
timer.setInterval(2000L, myTimerEvent1);
timer.setInterval(2000L, myTimerEvent2);
BlynkEdgent.begin();
BlynkEdgent.run();
