What version of the Blynk library does the IDE report?
How do I see the version of Blynk installed?
#define BLYNK_FIRMWARE_VERSION “0.1.0”
Are you sure you’re the right person to be developing an application for a client of your company?
Sketch > Include Library > Manage Libraries
Type “Blynk” in the search bar
What version is installed??
Version 1.0.0 beta.3
Should be 1.0.0
I will downgrade…
Wait…
#define BLYNK_TEMPLATE_ID "TMPLU4fPULV6"
#define BLYNK_DEVICE_NAME "LED BLINK"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
BLYNK_WRITE(V4)
int pinValue = param.asInt();
digitalWrite(2, pinValue);
pinMode(2, OUTPUT);
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
Serial.println("Rodando...");
Did not connect. My code is this above.
I’m guessing that you’ve missed-out some steps in the process, such as adding the template to the app and doing the “add new device” process.
Is the library correct now?
I will redo the whole process again.
If you have 1.0.0 installed then yes.
