I am working on my project “Water level indicator using esp8266”. Before that, I tried it on a simple LED and it worked well. Then I created blynk template and device for water level project. When I uploaded code of my project, blynk was still offline. I have checked BLYNK_AUTH_TOKEN and my wifi credientials many times and they are correct. Then I again gave that BLYNK_AUTH_TOKEN to LED code and that again started working again and went online. Need senior’s help…
LED CODE:
#define BLYNK_TEMPLATE_ID "TMPL6HjBGPaAV"
#define BLYNK_TEMPLATE_NAME "8266"
#define BLYNK_AUTH_TOKEN "GVSdVdHUhfXRLaUybqyNorryRd949ehu"
char ssid[] = "*******";//Enter your WIFI name
char pass[] = "*******";//Enter your WIFI password
//Get the button value
BLYNK_WRITE(V0) {
digitalWrite(D0, param.asInt());
//Set the LED pin as an output pin
pinMode(D0, OUTPUT);
//Initialize the Blynk library
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
//Run the Blynk library
WATER LEVEL CODE:
#define BLYNK_TEMPLATE_ID "TMPL6L3c2JPds"
#define BLYNK_TEMPLATE_NAME "LED"
#define BLYNK_AUTH_TOKEN "Gw9IOWrfpmMPiKkzH_tXAIrVQN-_EnvC"
//Set Water Level Distance in CM
int emptyTankDistance = 150 ; //Distance when tank is empty
int fullTankDistance = 40 ; //Distance when tank is full (must be greater than 25cm)
//Set trigger value in percentage
int triggerPer = 10 ; //alarm/pump will start when water level drop below triggerPer
#include <Adafruit_SSD1306.h>
#include <AceButton.h>
using namespace ace_button;
// Define connections to sensor
#define TRIGPIN D6 //D6
#define ECHOPIN D7 //D7
#define wifiLed 16 //D0
#define BuzzerPin D3 //D3
#define RelayPin D5 //D5
#define ButtonPin1 3 //RX //Mode
#define ButtonPin2 10 //SD3 //Relay
#define ButtonPin3 D4 //D4 //STOP Buzzer
//Change the virtual pins according the rooms
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
float duration;
float distance;
int waterLevelPer;
bool toggleBuzzer = HIGH; //Define to remember the toggle state
bool toggleRelay = false; //Define the toggle state for relay
bool modeFlag = true;
String currMode;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
//Serial.println("Blynk Not Connected");
digitalWrite(wifiLed, HIGH);
if (isconnected == true) {
digitalWrite(wifiLed, LOW);
//Serial.println("Blynk Connected");
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_3) {
modeFlag = param.asInt();
if(!modeFlag && toggleRelay){
digitalWrite(RelayPin, LOW); //turn off the pump
controlBuzzer(500);
currMode = modeFlag ? "AUTO" : "MANUAL";
BLYNK_WRITE(VPIN_BUTTON_4) {
if(!modeFlag){
toggleRelay = param.asInt();
digitalWrite(RelayPin, toggleRelay);
controlBuzzer(500);
else{
Blynk.virtualWrite(VPIN_BUTTON_4, toggleRelay);
BLYNK_WRITE(VPIN_BUTTON_5) {
toggleBuzzer = param.asInt();
digitalWrite(BuzzerPin, toggleBuzzer);
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.virtualWrite(VPIN_BUTTON_3, modeFlag);
Blynk.virtualWrite(VPIN_BUTTON_5, toggleBuzzer);
void displayData(){
display.clearDisplay();
display.setTextSize(3);
display.setCursor(30,0);
display.print(waterLevelPer);
display.print(" ");
display.print("%");
display.setTextSize(1);
display.setCursor(20,25);
display.print(currMode);
display.setCursor(95,25);
display.print(toggleRelay ? "ON" : "OFF");
display.display();
void measureDistance(){
// Set the trigger pin LOW for 2uS
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
// Set the trigger pin HIGH for 20us to send pulse
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(20);
// Return the trigger pin to LOW
// Measure the width of the incoming pulse
duration = pulseIn(ECHOPIN, HIGH);
// Determine distance from duration
// Use 343 metres per second as speed of sound
// Divide by 1000 as we want millimeters
distance = ((duration / 2) * 0.343)/10;
if (distance > (fullTankDistance - 10) && distance < emptyTankDistance ){
waterLevelPer = map((int)distance ,emptyTankDistance, fullTankDistance, 0, 100);
Blynk.virtualWrite(VPIN_BUTTON_1, waterLevelPer);
Blynk.virtualWrite(VPIN_BUTTON_2, (String(distance) + " cm"));
// Print result to serial monitor
// Serial.print("Distance: ");
// Serial.print(distance);
// Serial.println(" cm");
if (waterLevelPer < triggerPer){
if(modeFlag){
if(!toggleRelay){
controlBuzzer(500);
digitalWrite(RelayPin, HIGH); //turn on relay
toggleRelay = true;
else{
if (toggleBuzzer == HIGH){
digitalWrite(BuzzerPin, HIGH);
Serial.println(" BuzzerPin high");
if (distance < fullTankDistance){
if(modeFlag){
if(toggleRelay){
digitalWrite(RelayPin, LOW); //turn off relay
controlBuzzer(500);
else{
if (distance > (fullTankDistance + 5) && waterLevelPer > (triggerPer + 5)){
digitalWrite(BuzzerPin, LOW);
displayData();
delay(100);
void controlBuzzer(int duration){
Serial.println(" BuzzerPin HIT");
delay(duration);
// Set up serial monitor
// Set pinmodes for sensor connections
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(RelayPin, OUTPUT);
pinMode(BuzzerPin, OUTPUT);
pinMode(ButtonPin1, INPUT_PULLUP);
pinMode(ButtonPin2, INPUT_PULLUP);
pinMode(ButtonPin3, INPUT_PULLUP);
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
button1.init(ButtonPin1);
button2.init(ButtonPin2);
button3.init(ButtonPin3);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;);
display.setTextColor(WHITE);
WiFi.begin(ssid, pass);
timer.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 2 seconds
timer.setInterval(1000L, measureDistance); // measure water level every 1 second
Blynk.config(auth);
delay(500);
button1.check(); //mode change
button3.check(); //buzzer reset
if(!modeFlag){ //if in manual mode
button2.check();
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT1");
switch (eventType) {
case AceButton::kEventReleased:
//Serial.println("kEventReleased");
if(modeFlag && toggleRelay){
controlBuzzer(500);
modeFlag = !modeFlag;
controlBuzzer(200);
break;
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT2");
if(toggleRelay){
else{
digitalWrite(RelayPin, HIGH); //turn on the pump
toggleRelay = true;
controlBuzzer(500);
break;
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT3");
toggleBuzzer = LOW;
break;
