Bundy
November 28, 2018, 3:33am
1
Is it normal for my arduino to basically reset if it looses connection with the server? If I had my nextion display running would the sketch keep running?
Gunner
November 28, 2018, 12:32pm
2
Yes and No… See here…
#9 Basic “Keeps running without WiFi or Blynk Server connection, but reconnects as soon as they are available” sketch
Simply does what the title says… Flashes the built in LED and sends UpTime data to both App and Serial monitor to show operation either way. Also has a lot of serial print commands to show general operation for troubleshooting… Remove them when you are comfortable that everything works for you.
http://docs.blynk.cc/#blynk-firmware-connection-management
#define BLYNK_PRINT Se…
