What's Blynk_h?
Hi, i have some error in my project
3. Add details :
My hardware: esp8266
• Samsung A14(Android 13, One UI Core 5)
• Indonesia
• Blynk at version 1.3.2
Here’s my code:
#define BLYNK_TEMPLATE_ID "TMPL6Yyn_YkCD"
#define BLYNK_TEMPLATE_NAME "MQ2 ESP8266"
#define BLYNK_AUTH_TOKEN "------"
#include <Blynk.h>
char ssid[] = "WiFiID";
char pass[] = "mypass";
BLYNK_WRITE (V0) {
  digitalWrite(D0, param.asInt());
  Blynk.begin(auth, "blynk.cloud", 8080);
  int sensorValue1 = digitalRead(D2);
  int sensorValue2 = digitalRead(D3);
  int sensorValue3 = digitalRead(D4);
  Blynk.virtualWrite(V1, sensorValue1);
  Blynk.virtualWrite(V2, sensorValue2);
  Blynk.virtualWrite(V3, sensorValue3);
  delay(100);
The issues:
[Unformatted compiler error message removed by moderator]
What’s Blynk_h for?
@mnafif24 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code and your compiler error message so that they display correctly.
just a wrong suggestion by the compiler. ignore it. Blynk_h is the include guard macro.
your include should be #include <BlynkSimpleEsp8266.h>
Done. Thx, Mr.Pete
No, you only did the code, not the compiler error message
