Hi Everybody,
I tested a demo-sketch first at home and the connection was successful.
Then I tested the same sketch inside the WIFi-network it shall work.
But there I get the error
13:28:11.029 -> ets Jun 8 2016 00:22:57
13:28:11.029 ->
13:28:11.029 -> rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
13:28:11.029 -> configsip: 0, SPIWP:0xee
13:28:11.029 -> clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
13:28:11.029 -> mode:DIO, clock div:1
13:28:11.029 -> load:0x3fff0030,len:1344
13:28:11.029 -> load:0x40078000,len:13864
13:28:11.029 -> load:0x40080400,len:3608
13:28:11.029 -> entry 0x400805f0
13:28:11.274 -> [39] Connecting to CAD-WLAN
13:28:11.940 -> [665] Connected to WiFi
13:28:11.940 -> [665] IP: 192.168.1.179
13:28:11.940 -> ___ __ __
13:28:11.940 -> / _ )/ /_ _____ / /__
13:28:11.940 -> / _ / / // / _ \/ '_/
13:28:11.940 -> /____/_/\_, /_//_/_/\_\
13:28:11.940 -> /___/ v1.1.0 on ESP32
13:28:11.940 ->
13:28:11.940 -> #StandWithUkraine https://bit.ly/swua
13:28:11.940 ->
13:28:11.940 ->
13:28:11.940 -> [675] Connecting to blynk.cloud:80
13:28:11.975 -> [716] <[1D|00|01|00] WX....Dd
13:28:17.957 -> [6719] Login timeout
13:28:17.957 -> [6720] Connecting to blynk.cloud:80
13:28:17.992 -> [6730] <[1D|00|01|00] WX6i.....zDd
13:28:23.982 -> [12733] Login timeout
13:28:23.982 -> [12734] Connecting to blynk.cloud:80
13:28:24.017 -> [12755] <[1D|00|01|00] WX6i.....Dd
In the target-WiFi-network where I get the timeout almost all ports are blocked. Does Blynk use some special ports?
Maybe it is really a timeout. The target-WiFi-network is known for sometimes slow responses. Is there a possability for me to increase the timeout-time?
How can I insert code that it gets presented as a code-section?
This is the code
#define BLYNK_TEMPLATE_ID "TMPLMdJba20T"
#define BLYNK_DEVICE_NAME "myFirstTemplate"
#define BLYNK_AUTH_TOKEN "WX6i....Dd"
#define BLYNK_DEBUG
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char auth[] = "";
char ssid[] = "SSID";
char pass[] = "PW";
WidgetLED led1(V0);
// V0 LED Widget is blinking
void blinkLedWidget() {
if (led1.getValue()) {
led1.off();
Serial.println("LED on V0: off");
else {
led1.on();
Serial.println("LED on V0: on");
timer.setInterval(3000L, blinkLedWidget);
best regards Stefan
