Hello i want to ask what is the role of the library SPI.h in a simple project.
what problems can be created if I remove it.
Thanks Nektarios
Thanks Nektarios
I can assume that if I don’t use a device or sensor that works with this protocol I can remove it from ny program.
Nektarios
Yes.
If you’re unsure then just comment it out and compile/upload your code. If it’s needed then you’ll soon find out and it’s a simple task to reinstate it.
Thank you
Nektarios
