Hi Everyone
What is the SSL lib for ESP32, I know the ESP8266 is BlynkSimpleEsp8266_SSL.h and where do I get it?
Hi Everyone
Presumably you’re looking for BlynkSimpleEsp32_SSL.h
which I think should be installed as part of the Blynk library.
If you are already running the latest library (0.6.1) and getting a file not found message then maybe you need to re-install.
Failing that, the file can be found here…
Thanks Pete … Just had to update my Blynk Lib.
