I change the color of some widgets based on whether something is done or not, or hot or cold, etc. I’d like to match the colors available in the widget settings. For example, the Green and Red colors I choose in the super chart. What are the exact HEX values for them? The green value I found from searching the web for green hex, is a real bright green…
Theme files are open sourced, you can grab colors from there:
https://github.com/blynkkk/blynkpix/blob/master/blynk-theme.json#L17-L48
thank you!
And you can customize your own colours to your heart’s content… and get the HEX codes to use for other projects.
