Here are my thoughts…
(1) It’s very rare that you have a situation where the 32 devices you want to control are all in the same physical area. Usually, these devices are scattered around a large space, and in this situation its often better to have multiple devices with a smaller number of relays connected to them, in different locations around the building.
In my case, I control many individual devices with plug-in “Sonoff” type smart switches that are all controlled via Blynk. If you do indeed have 32 devices all wired back to one location then go with your initial plan.
Using a singe 32-way relay board is generally not a great idea. If one relay fails then you have to remove the whole board and replace the entire board or the faulty relay. I find that it’s far better to use 4 or 8 relay boards instead, and have a few spare (and some replacement relays that you can use to repair a faulty board).
Your choice of MCU board is awful! I wouldn’t accept one of these boards if someone gave me one for free. Far better to us a NodeMCU and two MCP23017 expansion boards instead, as described here…
Using the MCP23017 IO Expansion Board -
If you want physical buttons to control each of the relays (often a good idea) then you’ll need 64 GPIO pins (so four MCP23017) and the Mega doesn’t have enough pins.
Offline functionality isn’t currently available in Blynk IoT.
Your Mega (or NodeMCU if you go down the MCP23017 route) counts as a single Blynk device.
